Thread: Help!!!Vectra 05 1.9 SRI CDTI power problem!
    Nov 2012
    BURY
    Default Help!!!Vectra 05 1.9 SRI CDTI power problem!
    Hello, I'm new on here but I'm wondering if anybody could give me an idea on what could be happening with my car!
    A couple of weeks ago, the car missed slightly every now and again. I wasn't sure if there could be something to do with the fuel so bought some Redex in the hope it might help.
    Anyway, it hasn't! Yesterday my car was missing a lot - it felt for a split second like it had lost power but as quick as it went, it came back. It then also started cutting out sometimes whilst stood still. It wasn't a stall, it just cut out but started up again fine.
    I'm just wondering if anybody else has experienced or known of this and what it could be and how much roughly it could cost to fix?
    All mechanics can't understand what is wrong in car!!!!
    Sorry about the long essay!!!!
    Thanks for any help!
    sol
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Is the spanner light on?
    Might be worth checking the vac pipes for splits. Check the swirl bar is attached. Remove and clean the EGR and boost sensor. Change the fuel filter.
    HTH
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Possible injector fault
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Nov 2012
    BURY
    no spanner light on!!!
    Change the fuel filter 2 time!!!
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    I had that happen to me today. I replaced throttle plug and thermostat plug wiring loom for a new one tonight as it kept cutting out, just like you. Found the throttle wiring insulation completely stripped off by heat!
    Check no wirings are in contact with each other and insulation is intact. Check all plugs are properly plugged in.
    Throttle body is about half foot up from thermostat housing. Follow wiring loom. It'll fork out to top of engine. But carry on away from engine to under a block. Thats the throttle body unit.
    Hope you'll find the issue. Report to us ;-)
  1. Vectra 05 1.9 SRI CDTI power problem!
    By sammcc15 in forum Vectra C / Signum Troubleshooting
    Last Post: 17th July 2012, 20:57
  2. PLEASE HELP! CDTI 150 Power loss problem
    By jujitsuboy69 in forum Engine & Drivetrain
    Last Post: 12th April 2010, 23:12
  3. Signum cdti 150 power steering problem...
    By mr-s in forum Vectra C / Signum Troubleshooting
    Last Post: 28th November 2009, 12:11
  4. 1.9 CDTi 120bhp power problem !!
    By sthomson1 in forum Engine & Drivetrain
    Last Post: 12th March 2009, 22:09
  5. 1.9 CDTi 120bhp power problem !!
    Last Post: 11th March 2009, 22:17
