Thread: Weird jolt while driving
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default Weird jolt while driving
    As title, the car jolts as if brake is tapped for a mere 1/100th second when changed to 2nd gear. This is 2nd time it happened. 1st was yesterday.
    1st revs fine. 2nd gear revs the jolts the revs fine.
    Any idea?? No codes came up.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Ok, fuel remains in tank just above red markers, and car cuts out as if its starved of fuel! No fault on dash... Anyone??
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Took car to garage and cut out. Luckily i brought laptop with me...
    Codes...
    P1125-21 throttle actuator feedback single range/performance
    P0638-01 electronic throttle control high voltage
    Whats up???
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Found issue... Exposed wiring for near temp sensor. So removed both throttle plug and temp sensor as temp sensor wiring was ruined. Used heat shrink tubes to insulate the wirings as i paired them. Starts car and its running better now.
    Photo below showing exposed wires, all of them right to plug! I had to split them up and drive slowly home.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Am surprised no one assisted on my today's issue! :-(
    Jul 2011
    Leeds
    Vehicle : Insignia 160
    Trim : Elite Leather Light n Sight
    Engine : 2.0 16v
    Year : 2012
    Mileage : 50k
    Quote Originally Posted by Humourbash View Post
    You had the car at a Garage,with your Laptop within 1 hour and 50 minuets of your first post !
    No one would have had time to help you.
    And why would you post for help when you were quite capable of fixing it yourself as you've quickly told everyone about ?
    'Trumpet and Blowing' spring to mind here mate ?
    Administrator plasma's Avatar
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    first time i've seen this post at all, but glad u got it sorted.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    I was clueless as the laptop shown no errors. I didnt go to the garage. I thought fuel gauge was on the blink. So took it to fuel garage to fill up. Could not go up hill as kept cutting out. As if starved of fuel! Wife's uncle came down to take me to garage to get fuel. He read the laptop and we both had a quick look. We didnt know where throttle body was located. Til noticed wires to plug was not insulated. Black covered made it hard to see. I put me hands through and feel the wires. Coppers touching other wires. I split them up and start car, it starts and i was able to drive it home. Cutting out halfway. Bonnet open i separate them again and got going all way home !
    I was at a loss at the time of posting them. Thanks :-)
  1. strange jolt or misfire ??
    By stuthevaux in forum Engine & Drivetrain
    Last Post: 7th August 2012, 00:07
  2. Black thick ATF and Jolt when engaging drive on Auto Box
    By mditzel in forum Engine & Drivetrain
    Last Post: 14th September 2011, 22:27
  3. Replies: 2
    Last Post: 28th July 2011, 13:37
  4. limp mode on motorway driving.....driving me crazy!
    By big rich in forum Diesel Engine related
    Last Post: 27th August 2010, 05:24
  5. Jolt when step down from second gear to first - Automatic, Vectra 2003
    By cluckens in forum Vectra C / Signum Troubleshooting
    Last Post: 27th February 2010, 16:09
vauxhall vectra c starts to jolt when driving
insignia sri jolt
