Results 1 to 10 of 21
Thread: Problem accelerating up hill...high revs
    Feb 2012
    Sheffield
    Default Problem accelerating up hill...high revs
    Hi guys, I was wondering if anyone could help with this.
    Yesterday on my way home from work my '04 2.0ltr Vectra C had a problem on a steep hill. I go up this hill with no problems every day (ish) so, I was a bit surprised when It started to struggle. It was like as soon as the revs got to almost 3K it seemed to lose power and the revs just hit the roof. It did it a few times and then seemed to settle in 3rd gear.
    Any idea's
    It has got 114K miles on the clock but, it's usually quite sound.
    Cheers very much.
    Dave
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    First thing to do is check all of your vacuum pipe work the rubber joints perish and split. I would also check the boost/inlet and inter-cooler pipe work as these are also known to split. they can be hard to find as they expand when the car is booted/under boost. The above is a common fault with the dti and quitw a simple fix.
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Is it manual or automatic, at that mileage it could be the clutch starting to wear? Does it do it on every steep hill or was it a one off occurence?
    3.2 v6 Signum and loving it
    Feb 2012
    Sheffield
    Thanks for the replies guys! It's a manual John and this is the first time its happened. I'm gonna give it another run tomorrow and see how it goes.
    Signum, is any of the above likely to be an expensive repair do you think?
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Hope it is the vacuum pipes, as they are not expensive to change.
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    from the original post it sounds more like the clutch is away , mine did the same once or twice so I replaced the lot rather than wait for it to go all together & leave me stranded .
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    have to agree on clucth, as it sounds like this car seems to have no problem reving, however its loosing this power as its slipping when been transferd thorugh the clucth, that my guess any way.
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    Quote Originally Posted by Kerr81 View Post
    its not too expensive, I had mine changed at the same time I changed my dmf, there was nothing wrong with either just misdiagnosed by a vauxhall dealership for a change.
    i only paid a couple of hundred quid to have it done, they do it with the engine in. They need to drop the NS subframe which enables them to remove the bell housing and get at the clutch etc. Not sure on clutch prices, i bought an original that was 'shop soiled' (it had a dirty box, oooerrrrr) for about £70.
    Trim : Sport
    Engine : Petrol
    If all of your pipe work comes back ok then with the over revving and no power lack of movement then I agree it could be the clutch on its way out. I would still check the hoses first as this is the cheapest fix. Once these have been ruled out move on to the next possibility.
    Do you get a car spanner light when the car struggles to get up the hill?
    Feb 2012
    Sheffield
    Thanks again guys! I will get it all checked out I reckon. Bleeding car grrr! lol
    Signum,-Steve, no dash lights came on at all when it happened but, the spanner (engine management?) light has always come on upon first start up of the engine for about 60 secs.
    I spoke to loads of garages about this but they all said that unless the light stays on then there's nothing to worry about...could this be an indication to anything?
  1. high revs
    By andy_richmond in forum Engine & Drivetrain
    Last Post: 12th October 2012, 18:43
  2. high revs no power
    By veccyDaz in forum Engine & Drivetrain
    Last Post: 29th May 2012, 18:31
  3. loss of turbo when accelerating in high gear
    By Bigglesfliesundone in forum Engine & Drivetrain
    Last Post: 12th October 2011, 09:54
  4. high revs when hot
    By mentor in forum Engine & Drivetrain
    Last Post: 26th May 2011, 12:36
  5. Strange noise when accelerating in too high a gear
    By Knuckle in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2011, 12:25
vauxhall vectra c no power uphill
Vectra c revving high on hills
