Results 1 to 10 of 11
Thread: 2006 2.2 Elite petrol head gasket again!
    Jul 2009
    Littleborough
    Default 2006 2.2 Elite petrol head gasket again!
    March 2011 the cam chain jumped and bent a few valves. Had it done at local garage. Less than 10,000 miles later November 2012 the head gasket has gone kaput. No water in top up bottle but plenty of diluted oil. First indication was when low coolant level light came on.
    Local garage is concerned as he can't see why it has happened. Apart from it being assembled or torqued down out of sequence the last time. Has anybody any ideas? I do have faith in the garage owner’s abilities but I am a bit jittery about holding on to the car after this but Christmas is coming and the buying of another car is a bit of a worry at the moment.
    The garage owner recommends moving the car on when it is repaired.
    Dec 2011
    Seaham
    Did they skim the head?
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    doesn't the water pump run off the timing chain on these ??
    don't know for certain but think it may be possible for the water pump seals to fail & put coolant into the oil .
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Jul 2009
    Littleborough
    Quote Originally Posted by Ben50n View Post
    I believe so.
    Jul 2009
    Littleborough
    Quote Originally Posted by DTi Elite View Post
    Thanks for this, I will mention this just in case he hasn't checked.
    Jul 2009
    Littleborough
    The mech said the oil and water can't mix this way. If he's wrong and it starts passing water into the oil again can someone let me know how this happens exactly then I can explain.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Its super rare for the head gasket to go on these engines. The Chain is oil fed, and the waterpump is also run off the chain as said, I wouldn't have thought oil could get into the water this way but water into the oil would be possible I believe.
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Vehicle : Vectra C estate
    Trim : SRI
    Mileage : 79000
    long shot but does the 2.2 petrols have an oil cooler? i remember my old vec b gsi had oil in the water and it was a split oil cooler
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by neill View Post
    No mate, you can fit one from the vx220 2.2 but its air cooled not water cooled like the v6's
  1. Head gasket gone!
    By Legion84 in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2012, 22:12
  2. Head Gasket help please !!
    By mark_647 in forum Engine & Drivetrain
    Last Post: 4th April 2009, 11:57
  3. 3.2 v6 head gasket
    By brooky888 in forum Introduce yourself.
    Last Post: 28th January 2009, 19:44
  4. Head Gasket 2.2 petrol?
    By vectrasri03 in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2007, 19:15
