Thread: 1.9 150 vectra problem
    Nov 2012
    n.ireland
    confused 1.9 150 vectra problem
    hi guys i hope you can help, my vectra feels abit juddery and just doesnt run smooth.
    i have recently replace the wire's on 3rd injector (was faulty)
    checked the egr valve and it was spotless as the previous owner had already fitted a blanking plate.
    now the only other thing i can think of from reading this forum (very helpfull btw) is the swirl flaps/linkage.
    i have read that the linkage has usualy come loss but i took a look this morning and it seems to be tight on.
    is the any way to no for sure that it is the inlet i need to change as i know this an expensive fix and theres alot of work involved?
    also the are no fault codes coming up or lights
    thanks for any replys
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    The swirl flaps don't usually cause juddery performance. Sounds to me like it could be either the throttle bode circuitry or if you haven't replaced the wiring on the other injectors maybe one of these.
    Nov 2012
    n.ireland
    thanks for the quick reply. no i haven't changed the rest of the injector wire's yet but i don't think it is this as when the 3rd one went she run on 3 cylinders so very noticeable.
    do you no if there is anyway of checking its the throttle body?
    Nov 2012
    n.ireland
    also do you know if the swirl flap linkage is meant to move when the car is rev'd?
  1. Vectra wiper problem - any advice appreciated - Vectra C
    By newbreed in forum Electrical & ICE (including SatNav)
    Last Post: 13th May 2011, 20:57
  2. air con problem vectra c
    By stevenrwaller in forum Electrical & ICE (including SatNav)
    Last Post: 20th July 2010, 10:03
  3. Vectra C Problem
    By johnny1983 in forum Engine & Drivetrain
    Last Post: 16th November 2009, 12:56
  4. vectra c problem help
    By beemerboy31 in forum Troubleshooting
    Last Post: 29th January 2009, 23:39
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
