Thread: Headlight Question for the MOT Testers Amongst Us
    South east
    Default Headlight Question for the MOT Testers Amongst Us
    ...or any other well-informed bod. My headlight aim seems to be too low, in that whilst the brightness is fine, the range is too short, and I can no longer see the top of the headlight beam when I park up at home in front of my garden wall. So I took it to my usual MOT place where the owner checked the alignment with the machine, but because he was in a hurry and he's monosyllabic at the best of times, getting info was like pulling teeth.
    Basically, he said the alignment is fine, just 2mm too low on the machine, which he said is not worth rectifying; (2mm too low on a machine just a foot from the car probably translates to a metre or more at the end of the headlight's range on the road though, so I'd like that 2mm back). He then said "it would have passed the MOT [in May] because it's so close to the minimum mark", which I guess means that 2mm below the min mark is just about ok to get a pass.
    Here's my question though: is there a specific height that the beam has to be set at, or is there a range, i.e. a minimum level and a maximum level? This is so I know how much to adjust the beam upwards by - i.e. just the 2mm I'm missing, or can I go further and still be within the correct range?
    Many thanks.
    Regular Member Mr Owens's Avatar
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    There's about a 5-10mm difference between min and max on the beam tester, just adjust them on the gauge while the headlight setting is on 1 and while your driving just switch to 0 setting to raise the beam height
    Regular Member Sierra2's Avatar
    Sep 2010
    London
    Trim : SRI
    Engine : 1.9cdti (120)
    Mileage : 45k
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Depends on the beam setter tbh, You could have asked him to adjust them as high as possible
  1. vec C 04 reg headlight question
    By mick.n in forum Vectra C / Signum Car Chat
    Last Post: 21st November 2010, 14:01
  2. Headlight Question
    By SRI456 in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2010, 22:25
  3. Question for any MOT testers out there...
    By damian s in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2010, 21:53
  4. headlight question.
    By shan in forum Electrical & ICE (including SatNav)
    Last Post: 3rd November 2008, 15:46
  5. Headlight Question
    By Bethan39 in forum Vectra C / Signum Car Chat
    Last Post: 25th August 2005, 18:59
