Results 1 to 3 of 3
Thread: 3.2 , bad breathing , high idle , issues
    Regular Member biffbangpow's Avatar
    Jul 2012
    ferryhill
    Vehicle : vectra
    Trim : gsi
    Engine : 3.2
    Year : 02
    Mileage : 96k
    Default 3.2 , bad breathing , high idle , issues
    OK
    just topped the washer fluid ,and checked the oil cap
    its full of crap , just like it was when i bought the car
    cleaned it out and did the tb , which was manky
    however i would like to get this sorted
    how do we remover the plenum , so we can explore more , pipe onto the inlet , is first port of call
    suspect the rocker covers might need doing !
    any thoughts !
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    If you have mayo and still have the plastic extension for the oil cap this is normal with short runs on the 3.2 remove the plastic extension and put the cap directly on. then your mayo issue will be gone.
    I'm not to sure about the other!
    Jul 2012
    ferryhill
    Vehicle : vectra
    Trim : gsi
    Engine : 3.2
    Year : 02
    Mileage : 96k
    thanks will try that
  1. High idle revs
    By Kaz in forum Engine & Drivetrain
    Last Post: 15th December 2013, 23:18
  2. High idle speed
    By 19CDTi in forum Engine & Drivetrain
    Last Post: 1st July 2012, 11:02
  3. Signum 2.8V6T idle speed high
    By BYGino in forum Engine & Drivetrain
    Last Post: 30th June 2011, 20:59
  4. Help - High idle (1000 rpm) and high map reading
    By roswell in forum Engine & Drivetrain
    Last Post: 5th April 2011, 21:49
  5. Very high idle speed (3500rpm)
    By CodeV in forum Engine & Drivetrain
    Last Post: 19th February 2010, 01:08
