Thread: Replacing Inlet Manifold and blanking EGR Valve in Northern Ireland
    Jul 2011
    Northern Ireland
    Default Replacing Inlet Manifold and blanking EGR Valve in Northern Ireland
    Hi there.
    Been following this site for some time but this is the first time i have posted. Been reading up all the stories on the inlet manifold problems. After checking my car it seem that my swirl flaps are done as there is oil leaking out around the 4th swirl flap. car is booked in for service soon so will be looking to change the manifold etc soon after this.
    were can i get the EGR blanked in Northern Ireland and maybe even the manifold replaced at the same time?
    any help or info would be greatly appreciated.
    Regular Member farley2708's Avatar
    antrim n.ireland
    hi man,whereabouts in norn iron are you? you can buy a Fiat blanking gasket which goes between the EGR and the manifold,if you look on ebay you can buy an oval blanking plate for the lower pipe
    i'll PM you pics of them,as for the manifold buy it from LMF vauxhall,cheaper than from stealers for the same thing,check that it is the updated version with the better swirl pots
    Jul 2011
    Northern Ireland
    Thanks for the info.
    now just need to sort out getting it mapped
    antrim n.ireland
    Autotune in ballymena,will remap it for you 180bhp & remove the EGR from the ECU,off the top of my head £275 if you have a DPF they map that out aswell
    Jul 2011
    Northern Ireland
    thanks.
    forgot to say as well im from the fermanagh area. will have to look into the mapping
  1. Inlet Manifold replacing - What gaskets are required please?.
    By thefibreguy in forum Engine & Drivetrain
    Last Post: 15th March 2012, 20:38
  2. Replacing My Inlet Manifold (Help)
    By corderz in forum Diesel Engine related
    Last Post: 17th February 2011, 18:33
  3. is it worth blanking with new inlet manifold (cdti 150)
    By monty2000 in forum Vectra C / Signum Car Chat
    Last Post: 6th July 2010, 20:35
inlet manifold blanking service signum
mapping out egr valve vectra c www.vectra-c.com
Wher can i buy a blanking plate in ballymena ni
Where to buy blanking plates in ballymena
Where to buy egr blanking plates in ballymena ni
