Results 1 to 10 of 27
Thread: Who has done a head removal and refit on a CDTI150???
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Default Who has done a head removal and refit on a CDTI150???
    Who has personally done one - and how long did it take you?
    Administrator plasma's Avatar
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    not I said the wolf, but more than likely your going to?
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    I am sure Lee Mark Smith did this earlier this year after his cambelt snapped
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by plasma View Post
    Hey Dean - I may be being thick here - but not sure what you mean - lol!??
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    I havent removed the cylinder head before, but have removed everything else (inlet manifold,turbo,timing belt,injectors,cam carrier,vac pump etc) So i may be able to help with any questions on those specific things, but nothing on the cylinder head on a z19dth
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by XPCobra View Post
    How long did that process take you mate.
    I have done a turbo - and loads of timing belts etc. Just never actually removed a head.
    Thx
    A
    Dec 2010
    Glasgow
    Mileage : Near 100K
    I Had done it at different stages (and on different cars as i've never had to remove the cam carrier from mine)
    At a guess, between 8-12 hours to remove and refit a cylinder head if the injectors arent seized on a vectra (taking the front end off too), you could possibly make things quicker by removing the head with the inlet manifold and fuel pump still attached (if able to)
    Middlesex
    Trim : SRI
    Mileage : 100k
    I was thinking that mate... Keep on as muh as possible to limit what I need to strip. Would be VERY handy if you can remove the head without having to split of the inlet. thats already a new one.
    A
    Dec 2010
    Glasgow
    Mileage : Near 100K
    Why are you removing the head anyway?
    Middlesex
    Trim : SRI
    Mileage : 100k
    Glow plug tip snapped down in the head. As its only the tip of the plug thats jammed in - I cant extract it out from the top
  1. CD70 head unit removal
    By hothatch in forum Electrical & ICE (including SatNav)
    Last Post: 25th April 2012, 13:12
  2. Head removal help please
    By mdibb2009 in forum Engine & Drivetrain
    Last Post: 7th July 2011, 17:27
  3. Centre Console Removal/Refit
    By si_hoss in forum Bodywork & Interior
    Last Post: 5th October 2010, 14:26
  4. Wheel removal/refit
    By Gripper in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2009, 11:49
  5. Removal of Factory Fit Head unit
    By akulla in forum Electrical & ICE (including SatNav)
    Last Post: 7th November 2007, 18:36
1.9 cdti cam carrier removal
z19dth cylinder head removal
z19dth head removal
stripping 1.9cdti 16v cylinder head
vectra c 1.9 cdti recon headremoving rocker 1.9 vauxhall1.9 cdti head removalvectra c 1.9 cam carrierz19 engine cylinder head removal2002 vectra sri remove head1.9 cdti cylinder headremoving z19dth headhttps:www.vectra-c.comforumshowthread.php175852-Who-has-done-a-head-removal-and-refit-on-a-CDTI150vectra 1.9 cdti cylinder head removalcylinder head removal on z19dth enginehow to remove head on vectra c cdti 150 z19 dthremoving head on vectra c cdti 150head removal on a vectra 150 cdticdti 150 removing head
