Results 1 to 10 of 17
Thread: Oil level warking light & help
    May 2012
    UK
    Default Oil level warking light & help
    Hi all
    I've got an '06 1.8 vvt exclusiv with 42k miles. Last few days after doing a long journey (over 100 miles) the oil level warning light has come on.
    First time it happened I pulled over immediately and checked the oil - it is just slightly under the max mark. I started up again and the light went off immediately and stayed off for the rest of the journey. However yesterday it did the exact same thing - came on, then went off after stopping for a few mins. It does go immediately off on starting, it doesn't stay on a few seconds.
    Could this just be a sensor fault or something more sinister? The oil and filter were changed 10k miles ago by the (non Vauxhall) main dealer I got the car from. They said they had used official Vx oil and filter, and for the last 10k miles since the fill I've had no issue.
    I'm getting the oil changed next week in any case, and I'm a bit confused; the car has a main dealer history and up to the last service had been filled with 10w40. The last fill was 5w30. Thing is, according to the handbook 10w40 isn't recommended - is this correct?!
    Any help would be great. Thanks
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Quote Originally Posted by Chip View Post
    Hi all
    VX 5w30 on all vec-c models is the recommended oil
    May 2012
    UK
    Quote Originally Posted by AntSSSS View Post
    Thanks, would the 10w40 used previously cause any potential issues, for example the oil level light to come on? It has 5w30 now & the car runs great, everything seems ok - I hope!
    Middlesex
    Trim : SRI
    Mileage : 100k
    No - shouldnt have really. The fully synth 5w30 Dexos II GM oil is long life low ash so better for the engine / breather system.
    Regular changes and you should be OK.
    May 2012
    UK
    Ok great thanks! Any idea why a main Vx dealer would use 10w40?! I don't know if it was even Vx oil in that case. Bizarre.
    Also if anyone has any advice on the oil light prob that would be great
    Dec 2011
    Seaham
    Try a new oil pressure switch, they do go occasionally and it frightens the life out of you!
    hull
    10w 40 semi synth ok for vvt, just needs changing more often 10k, a mate at work uses it all the time, 180k on his vvt.
    May 2012
    UK
    Quote Originally Posted by Ben50n View Post
    It sure did! Is it an easy DIY job?
    May 2012
    UK
    Quote Originally Posted by frasedeb View Post
    Thanks, yeah the previous owner only did 5k miles per year so hopefully all ok! I'm going to use the proper Vx 5w30 synthetic stuff every 10k miles, hopefully will keep it running sweet. It's a cracking engine.
    Dec 2011
    Seaham
    normally unplug the wire, nscrew the old one out. screw in the new one and reconnect the wire!
  1. Oil light and water level light on and off :S
    By Wrig in forum Engine & Drivetrain
    Last Post: 22nd August 2012, 15:34
  2. Is this a low oil level light?
    By krazylegz in forum Vectra C / Signum Car Chat
    Last Post: 7th May 2012, 19:31
  3. Oil Level Light????
    By SomeboyMartinJ in forum Engine & Drivetrain
    Last Post: 3rd December 2011, 21:28
  4. Low Level Oil Light
    By rocket999 in forum Engine & Drivetrain
    Last Post: 8th August 2011, 01:40
  5. Oil level light
    By Cannonball2 in forum Bodywork & Interior
    Last Post: 4th December 2009, 10:58
