Results 1 to 3 of 3
Thread: parking sensor problems (speaker)
    Nov 2012
    south west
    Default parking sensor problems (speaker)
    hello everyone, had an sri 2.0 turbo for about a month now and love it but the front and rear parking sensors have never worked however will bleep from the dash when putting in reverse. right the owner that i bought it off took it to vauxhall to get them sorted and did say that they worked for a short while, this is their report as follows : parking sensors not working- warning light comes on but no sounds quote for repair only at this stage. no trouble codes stored, check fuse fr28- all ok. check data list - ok. check config (requires security pass). find fault with parking sensor ecu. replace as adv. required. test once fitted sensors now sound but only for a short period then dies away. trace additional fault to speaker in roof lining. now is it easy to get to the speaker and replace or is it a job for the dealers also where in the roof lining is it? any advice would be apreciated. many thanks
    Solihull
    Vehicle : safira
    Trim : Se
    Engine : 120
    Its just in from the back, if you pull the plastic section out and pull down the liner, its there.
    Basically just under where the antenna base is.
    I guess you could just replace with any speaker, there is space in the void under the antenna.
    Nov 2012
    south west
    Brilliant thank you, didnt want to start ripping the interior apart to find that its so easy to get to. now hoping for decent weather
  1. change parking sensor tone/speaker
    Last Post: 14th February 2010, 18:51
  2. Help with OEM parking sensor
    By andreitone in forum Electrical & ICE (including SatNav)
    Last Post: 10th June 2009, 09:55
  3. Vauxhall parking kit speaker
    By leeds vectra in forum Parts for sale
    Last Post: 12th June 2008, 00:06
opel vectra 2.8 turbo front parking sensor not working
zafira b location of parking sensors speaker
reversing sensor not working on insignia
vauxhall zafia dti 2010 parking sensor ecu
