Page 1 of 6 123 ... LastLast
Results 1 to 10 of 55
Thread: 3.0 v6 cdti coolant light on whilst drive..
    Regular Member yorkiesiggy's Avatar
    Apr 2012
    scunthorpe
    Question 3.0 v6 cdti coolant light on whilst drive..
    hi guys,
    i cant seem to find any threads regarding my fault so i was wondering if any of you guys could give me some of your knowledge with the (06 plate, y30dt-3.0 v6 cdti) engine.
    i have a coolant light problem were it only illuminates whilst under acceleration from a 30-70 just say then stays on, but if i drive round town running between 1.5/2.5 revs it doesn't come on.
    my siggy temp normally runs between 85 & 92ish when in towns but stays at 85 on A roads no matter what style of driving.
    as for the coolant level it tends to stay just above the cold/kalt mark..
    any ideas guys please?
    am just dreading the gaskets on the way out or sumort.
    The coolant system is probably blocked
    The temperature gauge on mine rises to normal temperature after about 10 minutes and never moves thereafter
    This also suggests the thermostat may have failed
    Regular Member ScottyV6's Avatar
    Feb 2011
    Worcester
    Does your temperature gauge not even go up when stuck in heavy traffic? Mine occasionally does to just below 90 but only in heavy stop-start traffic, (probably just before the fan kicks in) or when re-genning!
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    The coolant level should rise above the cold mark when warm/hot. What's the level like when it's cold?
    Apr 2012
    scunthorpe
    is it a hard job to bleed the system on this engine? and change the thermostat?
    Apr 2012
    scunthorpe
    Quote Originally Posted by ScottyV6 View Post
    went to pick the misses up and the light came on whilst driving to her so thought ad check to see the level of the coolant and it was about an inch under the cold mark, after getting home left it to cool for a few hours and checked again and it was just below cold line, put around 200ml in which took it to about half inch above the cold line.
    i will be doing a 15 mile trip soon so will see what happens if the light stays out, but i will check the level as well.
    i don't think i have put to much water in the tank to over fill it or have i ?
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Just to clear up is it coolant temp or level?
    If it's a cm bellow cold then that might be enough to bring level light on
    Apr 2012
    scunthorpe
    Quote Originally Posted by mattv6diesel View Post
    Its coolant problem temp seems to running as it should its just the light comes on after 10 mins of running,
    Not had an issue with the coolant in the 8 months i've owned it.
    Last edited by yorkiesiggy; 16th November 2012 at 19:07. Reason: Smart phones are crap on the quick replys
    Apr 2012
    scunthorpe
    Right got to work with no light now and the level was sat inbetween the 2 return hose's on the coolant tank, gunna go check whens its cooled down a bit,
    See if it drops to the cold level.
    wirral
    49 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Head gasket on its way
  1. coolant light help.
    By frasedeb in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd February 2011, 21:46
  2. coolant light
    By iam2103 in forum Engine & Drivetrain
    Last Post: 19th July 2010, 10:35
  3. spanner light whilst driving
    By porthy-t in forum Engine & Drivetrain
    Last Post: 8th November 2009, 17:27
  4. coolant light on
    By moles-sri in forum Engine & Drivetrain
    Last Post: 22nd June 2008, 11:57
  5. Coolant Light
    By bruceybonus in forum Engine & Drivetrain
    Last Post: 17th November 2005, 06:25
vectra 3.0 cdti coolant problems
how to bleed coolant system vectra c 3.0 v6
just put new thermostat in my vectra c and now radiator light on
y30dt removing head gasket rear bank
vectra c 3.0 v6 cdti bleed screw
vectra 3.0 head gasket front back
