Thread: vectra c 1.8 ecotec
    Aug 2012
    Dorset
    Default vectra c 1.8 ecotec
    i need help ill start from the beginning
    the car is a 2002 vectra 1.8 ecotec engine which i think is a z16xe engine
    it developed a real bad oil leak from the cambelt end so i put a new crankshaft oil seal in new cambelt and that hoping it wud be done started it up no sign of oil i thought great until i took it for a drive
    it was only a short drive and oil light came on got it back home opened the bonnet to find oil everywhere on cambelt side of engine again and i mean everywhere as it has been sprayed by the pullys
    does anyone have any ideas where it could be coming from i.e head gasket or is there any oil way plugs on that side of the engine
    i have tried to look on the net for engine pictures but no luck
    the car has only done 72000 just hoping its not engine gone really
    any help wud be much appreciated
    Dec 2011
    Seaham
    The only thing I can suggest you do, is, clean it all down, leave the cam belt cover off and start the car and watch for the oil. You did put the oil filler cap back on??
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    serrious problem if you lost the oil that quick, id do as benson said, where did u get the seal from? looks like its still coming from the area you went to fix, cant see this much oil escaping from the rocker cover gasket, ive not know oil to leak from the head gasket either unless something very serrious has happend.
    i think its still coming from the crank, possibly a wrong smaller seal was used by mistake?
    Aug 2012
    Dorset
    Thanks guys I don't think it was a genuine vauxhall one and from what I have read that's a bad idea ill strip it down again and have another look
    one thing it couldn't be the drill ways on the head where they still for the oil ways to go as the have to drill all the way through to get the swarf out just wondering
    ill keep u updating of what I find
    Aug 2012
    Dorset
    put a genuine vauxhall seal in it blew it out again as soon as i took it for a drive i ran it for 10 mins before all was fine seems to blow them out when driving
    could it be the oil pump over pressurising itself has anyone heard of this before is there a solution or is it a new pump
    also does anyone know of anywhere to get a cheapish one or has one lying around they no longer need
    Dec 2011
    Seaham
    I wouldnt have thought that there was an oil feed into the seal or near the seal, cams normally run in lubricated bearings, like your big ends? Sounds like your engine is building up pressure. internally??
    Aug 2012
    Dorset
    the seal im having problems with is the bottom crankshaft seal where the oil pump is i have just ordered a second hand oil pump £46 6 months warrenty to result so ill strip it all put it on and see what happens then
    ill keep you posted
    Regular Member keith1983's Avatar
    Sheffield / Spalding
    Vehicle : Vectra 1.8 SRi
    Engine : Z18XE
    Your engine is a Z18XE, did you get a part for a z16xe?
    Aug 2012
    Dorset
    i put the number wrong keith i just noticed that i did get the parts for a z18xe engine i have now put a second hand oil pump on it putting it back together now so fingers crossed it works fine if not looks like a new engine
    Aug 2012
    Dorset
    well second hand oil pump in all back together now took it for a drive and it still has all its oil so it looks like oil pump was over pressurising
  1. 1.6 16v ecotec question...
    By wrayballs10 in forum Engine & Drivetrain
    Last Post: 27th July 2011, 21:08
  2. ecotec rattle
    By stu-mk2 in forum Engine & Drivetrain
    Last Post: 1st November 2010, 22:21
  3. 1.6 Ecotec 16valve
    By Derek Mc in forum The 'Off Topic' room
    Last Post: 13th October 2010, 19:15
  4. Anyone know what ECOTEC stands for?
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 22nd June 2009, 22:20
  5. ecotec and vxl stickers
    By Morephun in forum Styling
    Last Post: 25th February 2009, 22:23
