Thread: How to replace the radiatior (2.0 DTI)
    Nov 2012
    Birmingham
    Default How to replace the radiatior (2.0 DTI)
    Is it possible to replace a Vectra radiator without jacking the car up?
    Basically, the car has front end damage, so the front bumper & bumper reinforcement bar will be removed and replaced anyway. So can it be done from there?
    Your help would be much appreciated.
    Edit: Should point out, it's a pre-facelift version.
    Nov 2012
    Birmingham
    Anyone got any clues?
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Yes. But intercooler radiator will need to be moved, air con rad moved then water rad is located there or are you replacing all 3?
    Bumper off,
    Bumper support bar off,
    Rads all accessible from there on!
    Photos please. Helps us see damage and help you further, also see your progress.
    Nov 2012
    Birmingham
    Quote Originally Posted by Humourbash View Post
    Bumper off,
    Thank you very much for that.
    I do intend to take pics when I get round to it, probably on Monday. I just wanted confirmation that it is possible. Taking the intercooler and air con rad, is that just a simple undo the bolts job?
    I'm just doing the water radiator.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Yeah, and disconnecting hoses. Take care with intercooler hoses, undo both ends of the hose and twist it outwards so its save. The water rad will have plastic intercooler hose tube mounted on the rear of water rad. So look behind on the right (on battery side) and disconnect hose from top. Then u have an easy disconnection. Air con pipes are bolted, if its full of working air con, take care as pressure will spray green stuff,
    This is from knowledge of facelift z19dth 1.9 150. Might vary of other models but can only guess it'll be a bit of likelihood it'll be similar.
    Get HIDs while u doing it. Fit ballast in place under headlight behind bumper. Perfect area to keep it cool. And protected
    Nov 2012
    Birmingham
    Sorry, I'm not familiar with all the abbreviations, HIDs?
    Edit: Ahh HID light lmao.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Quote Originally Posted by Whosane View Post
    Lol, if you want HID installed, 3 birds with one stone!
    Nov 2012
    Birmingham
    My bumper is currently f***** so I'm getting a new one. One of my fog lights is gone as well, so I'll be replacing that.
    Nov 2012
    Birmingham
    Yes. But intercooler radiator will need to be moved, air con rad moved then water rad is located there or are you replacing all three.
    I've taken off the bumper and the bumper bar now and the water radiator is the first one facing you so surely I wouldnt have to remove the intercooler radiator?
  1. How to replace the radiatior (2.0 DTI)
    By Whosane in forum Vectra C / Signum Troubleshooting
    Last Post: 12th November 2012, 00:24
  2. Cim Replace
    By Markov in forum Electrical & ICE (including SatNav)
    Last Post: 3rd May 2012, 22:58
  3. Replace 215/55/16 with 195/50/16
    By battsman in forum Suspension, Wheels & Brakes
    Last Post: 14th February 2012, 16:18
  4. Replace my TID with a dvd?
    By ryantcb in forum Electrical & ICE (including SatNav)
    Last Post: 30th June 2011, 15:46
  5. Tie rod replace
    By blackveccyC in forum Suspension, Wheels & Brakes
    Last Post: 28th November 2010, 15:15
