Thread: Safeguard check error and demister issue
    Nov 2012
    Wales
    Default Safeguard check error and demister issue
    Hi everyone,
    I've got a vectra c 1.8 vvt hatchback and over the last few days I'm getting the safeguard check on the display.
    today the demister on the back window has stopped working.
    are the 2 linked?
    any ideas how to fix demister and safeguard error?
    thanks guys
    Engine : 1.9 CDTi
    It uses the heater element as a glass break detector so possibly linked.
    Check the connections at the side of the screen where the power goes into it.
    Nov 2012
    Wales
    Hi lee,
    thanks for quick reply.
    when you say check do you mean check the actual lines that run through the glass? If so am I looking for cracks/breaks in the lines?
    sorry if I've Mid read
    cheers
    dean
    Engine : 1.9 CDTi
    For it to fully fail I would look at the sides under the plastic and try and see where the wire attaches to the screen as they can break off.
    Nov 2012
    Wales
    Ok thanks lee I did see the 2 screws at the top on the plastic. I'll take it off and see if anything had come loose :-)
  1. Rear Screen demister issue
    By Vaux-Man-G in forum Electrical & ICE (including SatNav)
    Last Post: 20th February 2013, 08:54
  2. check safeguard
    By rickh01 in forum Electrical & ICE (including SatNav)
    Last Post: 27th April 2012, 13:09
  3. Check Safeguard
    By Dazzy2006 in forum Electrical & ICE (including SatNav)
    Last Post: 10th October 2010, 10:25
  4. Check Safeguard
    By BaileySRI in forum Electrical & ICE (including SatNav)
    Last Post: 1st March 2010, 22:41
  5. safeguard check
    By marts cdti in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2008, 13:41
