Results 1 to 10 of 15
Thread: 2002 2.2dti
    Regular Member david.aka.judas's Avatar
    Suffolk
    Default 2002 2.2dti
    is there anything out there for mine?
    I need more now............lol
    especially, to get rid of the lag between gears.
    Tried K&N and it made it worse.
    many thanks
    Did you mod the airbox when you fitted the filter as i did just that to Mrs D's DTI and i got 17BHP and 20 lb/ft of torque !!!!!!!
    P.S and there is much less lag between gears !!!!
    Suffolk
    no - tell me more pls.
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    You take out a piece of restrictive plastic in the bottom half of the box. there is a post about this somewhere on here. also try adding an extra inlet and dont forget to reset your ecu
    Regular Member dervdoc's Avatar
    Co.Armagh
    Question
    Quote Originally Posted by Mugualigwian View Post
    how you reset your ecu? i took that piece out of my air box but didnt notice any real difference
    Co.Armagh
    Quote Originally Posted by Judas View Post
    many thanks
    a remap will help alot but not sure if you have a hybrid ecu, if ya do ya may forget about remaping or fitting a tuning box!! i know as i have a hybrid ecu and cant do anything about it really
    Jul 2006
    Northampton
    Trim : Sri
    You can reset your ecu by removing the positive connection from the battery and leaving it off for 20-30 mins. i left for 30 when fitting my filter, just to make sure
    Co.Armagh
    Question
    so what does that do for your motor? will ya loose the radio code if ya leave the terminal off???
    Jul 2006
    Northampton
    Trim : Sri
    Yes it will reset the stereo as well. if you dont have the radio code you can go to vx and get it done or just dont reset the ecu. everything else will be fine but the engine will perform alot better after it has been run in
    Chester
    I hav a signum 2.2dti, in need of a new air filter i recon and was considering a k&n, is it worth it and are you advising reseting the ecu after fitting a k&n filter? also these airbox mods - Im unclear on what to take out.
  1. Vectra C 2002 Y20DTH Remap DTI 2.0 2002
    By richardkay007 in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2012, 14:18
  2. Does the 3.2 GSI 2002 have a DMF
    By gibsonk in forum Engine & Drivetrain
    Last Post: 22nd September 2010, 07:49
  3. Best place to buy op-com & will it work on 2.2dti 2002
    By Teza in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2009, 11:09
  4. 2002 Vectra C 2.2Dti Spanner Light Help
    By kktdragon in forum Engine & Drivetrain
    Last Post: 7th January 2009, 01:34
Vectra c 2.2 dti ecu reset by taking battery off
