Thread: Misting Up
    Oct 2010
    London
    Default Misting Up
    Morning all
    When I get in the car in the morning at the moment, usually the screen is a little bit misted over but not too bad, however when I start the engine and turn the blower on it then mists right over!
    I have checked the pollen filter, which while being dirty is not wet, the drain is clear and I'm not losing coolant so I doubt the matrix is leaking. There is no water on the carpets or seats, the window seals look like they are OK and I've not been using the air conditioning.
    Any ideas on what on earth is causing it?
    Cheers guys
    slough
    Condensation or the matrix is sweating I think your matrix is on its way out mr……
    Oct 2010
    London
    Hard to get to the heater matrix?
    Quote Originally Posted by Homer View Post
    Then you should. In conjunction with the heater it makes for an excellent demister.
    AC is for all year round use, not just for hot days.
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    edit
    Oct 2010
    London
    Totally agree with you, Dave, and I often do. However when it gets too cold for the a/c to run I will be doubly stuffed with this issue!
    Double checked all of the carpets for sign of water earlier and couldn't find any. Are there any hidden drain holes which may be blocked?
    The dehumidifier part of the AC will still work in cold weather.
    I run my AC (ok, climate control) all year round and the only time I suffer misted windows is if I sit in the car for any length of time with the engine switched off. As soon as I start it up and put the blower on it clears within a minute or two.
    Oct 2010
    London
    The A/C is disabled at a certain point according to Vauxhall... and I'm pretty sure my car does disable it at around 2c, as turning it on makes no difference. But yes it is an excellent demister and does work a treat while I can still use it, I'm just thinking ahead to the real cold dark winters, and the possibility of water getting in somewhere.
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    have a sneak peak behinde the door panels, make sure the vapour barrier is still attached and in one peace.
  1. n/s fog sill misting
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2010, 20:13
  2. Window Misting up!
    By Avenged in forum Bodywork & Interior
    Last Post: 29th December 2008, 16:57
  3. Car windows misting up
    By Cerealuk in forum Vectra C / Signum Car Chat
    Last Post: 3rd October 2007, 23:49
  4. Headlights misting up in the wet...?
    By David_SRi_2.2DTi in forum Vectra C / Signum Car Chat
    Last Post: 17th August 2007, 20:35
  5. Misting Up
    By cdtisri in forum Vectra C / Signum Car Chat
    Last Post: 14th October 2005, 22:18
