Thread: Z20NET guru's...
    Regular Member blue estate's Avatar
    oh well.. I tried..
    Default Z20NET guru's...
    Right..
    Only when cold i.e first thing am or after the days work.. starts fine but goes into limp mode pretty much straight away.. stop start engine a few times in the journey and it clears fine until warm then all great.
    Code read car last night and nothing came up?
    I changed the water sensor (15393755) in March this year for same symptoms.. could this be belly up again? Any oter sensor or common problem i've over looked?
    Thanks in advance
    South east
    I suggest leaving it in limp home mode, i.e. don't switch the engine off to clear it, keep driving and a fault code should appear.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    The most common causes of limp mode on the 2.0T's are the boost sensors (one on the turbo, one on the inlet manifold) or the coils but without a fault code it's impossible to be sure.
    oh well.. I tried..
    Quote Originally Posted by Rebellion View Post
    I've tried that one mate a couple of days ago when it did it.. nothing came up
    Quote Originally Posted by Ian-Highlander View Post
    I have a pair of those from when i thought they was at fault but was the coil pack(s).. replaced all four of those brand new genuine items
    oh well.. I tried..
    Changed that water sensor again.. all seems ok *touch wood*
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    16 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Quote Originally Posted by blue estate View Post
    Was it a genuine sensor in the first place?...warrenty?...different replacement brand(if possible_ i hope..
    oh well.. I tried..
    Nope pattern part first time round.. pattern part again this time too. Not really bothered re warranty as i work in a motor factors so cheap enough
    Nov 2007
    DERBY
    16 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    ahhhhh
  1. any pc guru's out there?
    By tolly in forum General Chat
    Last Post: 18th July 2012, 21:12
  2. Scv guru's
    By s2yob in forum Y & Z30DT Specific
    Last Post: 17th November 2011, 21:46
  3. Search Guru's..... AGAIN..
    By Diet1985 in forum The 'Off Topic' room
    Last Post: 28th May 2009, 09:59
  4. One for the detailing guru's
    By rockh in forum Detailing and Car Care Discussion
    Last Post: 15th March 2009, 11:35
  5. Guru's
    By spoons in forum The 'Off Topic' room
    Last Post: 21st June 2008, 16:19
z20net common problems site:www.vectra-c.com
