Results 1 to 2 of 2
Thread: brake pad sensor
    Aug 2011
    north wales, criccieth
    Default brake pad sensor
    replaced both front and rear disks and pads on my 04 vectra cdti sri last week and whist i was there i noticed there was a stripped wire hanging around and iv had a brake warning light on for a while. i have been told it is a brake level warning indicator but i cannot find where this broken wire iv got hanging goes to. i was hoping i could repair the 2 ends back together for now to make sure this is my problem or just buy a new one if its cost effective.
    braking is not effected in the slightest with this but the light constatly on the dash is annoying!
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    The wires plug into a connector on the chassis leg and then run onto the stut and down to the pad. Twisting both wires together will extinguish the light until you get a replacement
  1. Fitting & Installation of ABS Harness & brake Help sensor sensor
    By Elahi_786 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2012, 20:46
  2. Brake sensor
    By kristian in forum Electrical & ICE (including SatNav)
    Last Post: 16th December 2010, 20:15
  3. Brake pad sensor - where does it go??
    By mishima in forum Suspension, Wheels & Brakes
    Last Post: 20th February 2010, 17:54
  4. brake pad sensor
    By andrew m in forum Suspension, Wheels & Brakes
    Last Post: 12th May 2009, 14:23
