Results 1 to 10 of 13
Thread: boost gauge
    Regular Member Swedge's Avatar
    Jul 2012
    Scottish borders
    Default boost gauge
    im going to be fitting a boost gauge to my cdti 16v
    i want it to read vacuum as well as boost
    will i get both just drilling the intercooler pipe?
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    No point, Diesels don't use vacuum as they are the petrol equivilent of wide open throttle. The throttle body on the intake if the CDTI is merely used for closing the intake when the engine is turned off.
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    As far as im aware, No.
    Jul 2012
    Scottish borders
    thanks
    Dec 2010
    Glasgow
    Mileage : Near 100K
    Quote Originally Posted by MrDerv View Post
    Diesels still have a vacuum, And the 'throttle body' (Intake shutter valve) Is there primaraly for the EGR valve
    Jul 2012
    Scottish borders
    i was only asking because having a vacuum reading can help with finding if you have a boost/vacuum leak
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    You'll get a vacuum reading from the Vac pump pipes. Don't touch the ones leading to the brake servo but you should be able to tap into the vac pipes before the boost solenoid
    Dec 2010
    Glasgow
    Mileage : Near 100K
    Quote Originally Posted by John IS3 View Post
    Would be pointless unless you wanted to moniter if your vacuum pump was working?
    Jul 2012
    Scottish borders
    but then i wont get a boost reading will i?
    Nov 2011
    You wont get a boost reading from the vacuum pipes. Boost reading will have to be taken from the intake, either on the manifold, or by putting an attachment on the intercooler boost pipe.
  1. How to fit boost Gauge ??
    By J18BES in forum Vectra C / Signum Car Chat
    Last Post: 3rd June 2012, 17:42
  2. boost gauge
    Last Post: 24th March 2012, 12:25
  3. Boost gauge help!!!!!!!!
    By tomo41 in forum Vectra C / Signum Troubleshooting
    Last Post: 26th June 2011, 17:36
  4. boost gauge
    By icetrix in forum Vectra C / Signum Troubleshooting
    Last Post: 28th March 2007, 21:01
