Going through my hand book it says that I can connect an external source. for example a GSM phone. Navigation system etc.
How is the connection made. Can it be done with out a visit to the stealer?
Thanks in advance
Thanks in advance
Any audio guru's or can it not be done?
It would seem no one knows.......! Ah well It looks like a trip to the stealers to pic their brains. lol
Have a seach for VDA plug, as you Might have that to be abel to do it.
Lost me there mate......but there's hope, I'll look into the vda plug, cheers. I don't suppose you could shed some more light on the subject could you? it would be much appreciated.
the VDA plug if you have it is hidden next to the glowbox , and can be use for phonekit ect.
thanks for the help kenp Ill look for the connector
I found this, so what do I need to make em work?
Either tap direct to the needed wires (pin layout is on the forum can be found via seach) or via a adaptor loom.
What you need very much depends on what you want to fit... im using that plug via a VDA adaptor to my Bury 6060+ handsfree kit.
