Thread: Coolant
    Full Member tubby's Avatar
    May 2007
    Norwich
    Vehicle : Vectra sri
    Engine : 2.2 z22se
    Default Coolant
    Hi guys my car seems to be using a little bit of coolant every few weeks, I keep topping it up to the level and 2-3 weeks later the warning light keeps coming back on. The engine temperature is the same and isn't over heating. Maybe I have a small leak but nothing visible. Starting to irritate me a bit now, could be anything more serious than a small leak? It's a 2.2 done 73k.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Take the header tank off and check for a small hair line crack at the rear, very common and only £20ish +vat for a new one from VX.
    May 2007
    Norwich
    Engine : 2.2 z22se
    Cheers mate ill have a look at the weekend
    Regular Member John Bishop's Avatar
    Oct 2010
    Had a similar prob with an omega afew years ago. No sign of leaks. Turned out the head gasket was on its way out
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Quote Originally Posted by John Bishop View Post
    Doom monster..................
    I had an Omega once ................ it gets you that way in the end.
    May 2011
    sunderland
    Hi mate mine was the same check the black pipe to the right of the engine if u cant squeeze the pipe then your hg has gone,also check for mayo in the oil filler cap sometimes an indication depending on where the hg has gone or a compression test will confirm but it sounds like it might cost you....hopefully not tho
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    If no leaks, it's more than likely to be the head gasket starting to fail
  1. coolant going somewhere
    By pud wayman in forum Diesel Engine related
    Last Post: 28th March 2012, 08:59
  2. which coolant ??
    By VecPower in forum Engine & Drivetrain
    Last Post: 30th October 2010, 18:04
  3. Coolant Top Up
    By alembicbassman in forum Vectra C / Signum Car Chat
    Last Post: 22nd October 2010, 15:54
  4. Coolant
    By Bloicy 3.2 V6 GSI in forum Engine & Drivetrain
    Last Post: 23rd August 2009, 12:19
  5. Oil in Coolant!!!!!!!!!!!
    By mipai in forum Vectra C / Signum Car Chat
    Last Post: 19th July 2009, 14:43
