Thread: injector replacement
    Regular Member smartalec0310's Avatar
    Apr 2012
    littleport
    Default injector replacement
    i am getting no.1 injector replaced tomorrow as its leaking alot of diesel. was just wondering if anyones had one done and what did it cost if you dont mind me asking. also it has to be programmed for the cylinder its in but does it programme itself first time its turned on? cause if thats the case i could change it myself.
    Engine : 1.9 CDTi
    When you say its leaking diesel do you mean out of the block onto the engine as they seal with a copper washer.
    And you need to program with Op-Com or Tech2 the serial number on it.
    Apr 2012
    littleport
    no its leaking from from where the soliniod (however its spelt) meets the injector so i think the seals inside the injector have broken down its done 130000k so its well run in lol. so i cant do it then lol
    Engine : 1.9 CDTi
    Not sure how well it would run without it being coded.
    Is there anyone local withTech2 or Op-Com that could program it?
    Apr 2012
    littleport
    i dont really mind im sitck to death of the car tbh always got problems atm so getting it done properly and the misses has spoken so cant be helped lol nevermind
  1. Replies: 8
    Last Post: 31st August 2012, 22:19
  2. Injector Seal Replacement
    By siz1 in forum Engine & Drivetrain
    Last Post: 24th March 2011, 10:53
  3. Injector replacement party with the V6CDTi
    By Celes in forum Diesel Engine related
    Last Post: 21st February 2011, 21:41
  4. Done the 3rd Injector plug replacement....
    By Dan_BlackSRi in forum Diesel Engine related
    Last Post: 3rd March 2009, 17:52
