Results 1 to 3 of 3
Thread: vectra 2.2dti hunting on idle. powerloss and smoke low revs.
    Regular Member fuzzyllogik's Avatar
    Apr 2012
    Bristol
    Default vectra 2.2dti hunting on idle. powerloss and smoke low revs.
    Hi, the problems started one after the other first the car broke down due to a dodgy MAF, the hotside to intercooler boost hose popped off and the EGR failed. I have replaced the EGR with new and the MAF with an after-market but not the car smokes noticeable at night time with occasional black smoke when it looses power this happens usually when cruising in 5th at between 12500 and 15000 revs, it also hunts every so often on idle and puffs a little smoke when it does. other than that it runs fine, starts from cold, mpg seems fine around 50 mpg down the motorway at 70. there is no mayo under the oil cap and the cooling system doesn't appear to be pressurised.
    ohh and when the car looses power between 12500 and 15000 revs and puffs black it will sometimes throw up an EGR fault code
    Any suggestions welcome before I rip off the turbo to inspect it or break down and cry to a mechanic.
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Hi m8 does your engine have the TP sensor on the inlet manifold or is it on the throttle pedal itself , just need to know as this is usually the source of the hunting tickover .
    Other problems could be a few things, split vacuum pipes , split in the intercooler hoses , inlet manifold and boost sensor needing a clean
    but firstly i would have the fault codes read that then give you an idea as to where to start looking
    if your not sure of your engines set up then post some pics of your engine bay we should be able to advise from there
    hth regards bob
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    I'm not surprised it smokes at 12.5k to 15k revs lol (too many zeros?)
    I'd get a genuine MAF as aftermarket ones can cause issues. I've used an aftermarket cheapie on a previous car and it ran like a dog, changed for a bosh one and all is good. Other than checking intercooler hoses for splits etc, i'd start here.
  1. Vectra c 2.2dti 2003 idle mode over 75mph
    By i_am_kev in forum Vectra C / Signum Car Chat
    Last Post: 31st March 2012, 18:29
  2. 1.8 club hunting for a few secs when idle..help
    By Fash in forum Engine & Drivetrain
    Last Post: 31st August 2011, 18:23
  3. white smoke n powerloss
    By Silver Vectra C in forum Vectra C / Signum Car Chat
    Last Post: 18th March 2011, 21:13
  4. Hunting idle on 2.0t
    By Morephun in forum Engine & Drivetrain
    Last Post: 17th June 2010, 12:35
  5. 2.0 T hunting on idle
    By stephen g in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2010, 20:33
vectra c 2.2 dti power loss
frontera dti loses power
engine hunts and smokes
vectra c 2.2 dti smoke
2.2dti smokes on idel
vectra revs hunting
frontera 2.2 dti smoking
vectra c 2.0 dti smokey on idle
vectra 2.2 dti power loss
vectra 2.2 dti smoking
vectra 2.2 smoke when starting car
opel 2.2 dti smoke
smoking 2.2dti
vectra 2.2 petrol engine hunting
vectra 2.2 low revs
