Results 1 to 10 of 17
Thread: master cylinder i think????
    Jul 2011
    United Kingdom
    Default master cylinder i think????
    Hi all just want your opinions please signum 1,9cdti 150 changed rear pads and now the pedal goes very slowly to the floor.bled it loads no change.is there anything else it could be or is it the master cylinder? If so ive been looking and can get one off fleabay for £60 or is there a better place to buy from for that money? Cheers guys.
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    16 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Did it do this before you changed the pads?...
    Regular Member beat275's Avatar
    Aug 2011
    Newcastle West Denton
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    Tech 2 for abs modulator
    Jul 2011
    United Kingdom
    No didnt do it before pad change.wound the caliper back in put new pads in then noticed the problem.as im driving i have some brakes but hold my foot on the at a junction and slowly goes to the floor.
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    sounds like air in the system to me.......
    did you open the brake fluid reservoir (top off ) before winding back?
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    were the sliders nice & free in the rubbers ?? any wear lip on the discs ?
    could still be bedding the pads in .
    Regular Member Craig1985's Avatar
    harwich essex
    Thought all diesels do this? Diesel creep ????
    May 2012
    county durham
    Mileage : 145k
    mine doesn't , the brakes are spot on as i recently replaced all the pads & made sure everything was 100% free .
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Pads not fitted correctly or not bedded in.
    Jul 2011
    United Kingdom
    Ok thanks for the replies.the pads were fitted correctly everything that need to move was doing so freely nothing siezed.ive done 80ish miles since changing the pads using the handbrake alot too to help bed them in the pedal is as hard as it shoul be and the brakes work fine but the pedal sinks to the floor when you hold it down im stumped?
  1. master cylinder
    By SarahP in forum Suspension, Wheels & Brakes
    Last Post: 1st November 2012, 15:15
  2. Anyone had to have a clutch master cylinder?
    By DaveW555 in forum Engine & Drivetrain
    Last Post: 13th April 2012, 22:56
  3. Anyone had master cylinder replaced?
    By n_hudson in forum Suspension, Wheels & Brakes
    Last Post: 21st June 2010, 12:04
  4. Master cylinder.
    By fluffsri in forum Suspension, Wheels & Brakes
    Last Post: 30th November 2009, 17:51
  5. Master Cylinder
    By parsco in forum Handling & Braking
    Last Post: 22nd January 2009, 11:38
