Thread: Instrument Dimming Bulb Output Circuit Open or High Voltage
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default Instrument Dimming Bulb Output Circuit Open or High Voltage
    B2652-05
    this now comes up. i dont know which part is this? the dash light dimming?
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    this is one and another code that really confused me.Generator Lamp "L" Control Circuit Malfunction what can i do to solve this two issues??? as when i clear the codes, the car with spanner goes off then 10 seconds later it comes back annd them two come back.
    slough
    Is`nt that on the light switch, i would check that first and probably the cheapest and easyier thing to swop over......
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Quote Originally Posted by hippo View Post
    i just checked and it dims just fine! weird issue i thought!
    Regular Member snake-man's Avatar
    Jan 2014
    nottingham
    Vehicle : vectra
    Trim : ls
    Engine : 1.8
    Year : 1996
    did you ever fix it as i have it to B2652 - Instrument Dimming Bulb Output Circuit Open or High Voltage
    VIP-Member sulten's Avatar
    Øvre Årdal, Norway
    Check the light bulb in the cigarette lighter collar.
    Kristian
    68 Diplomat-A 46S
    95 Vectra-A C20NE
    07 Vectra-C Z19DTH
    Aug 2016
    Croatia
    Vehicle : 1.9 CDTI
    Trim : Vectra
    Found the same error today and it's not cigarette lighter collar. Any other suggestions?
  1. B3803 - Comfort Closing Low Voltage or Circuit Open ???
    By Envy in forum Electrical & ICE (including SatNav)
    Last Post: 17th December 2012, 16:22
  2. boost pressure sensor input and output voltage???
    By FLOB in forum Engine & Drivetrain
    Last Post: 24th April 2012, 14:58
  3. P0380 - Glow Device Circuit Low Voltage
    By benwalters82 in forum Engine & Drivetrain
    Last Post: 5th March 2011, 01:13
  4. Replies: 9
    Last Post: 15th October 2010, 17:57
  5. MAFlow Voltage output.. Help
    By Imi in forum Vectra C / Signum Car Chat
    Last Post: 11th December 2008, 20:51
instrument dimming bulb output circuit open or high voltage
Vauxhall DTC B2652-05
b2652-05 vectra c
b2652-05 vauxhall
b2652 - instrument dimming bulb output circuit open or high voltage
b2652-05 opel
b2652-04 bulb dimming output circuit open
