Thread: Rumbling noise diagnosis please
    durham
    Trim : Leather
    Default Rumbling noise diagnosis please
    Hi guys long time no see I've had a rumbling noise on my NSF area for a fortnight now and it's getting worse as the speed increases, I'm thinking wheel bearing or driveshaft? Any ideas as to what the culprit might be? Thanks tony.
    Dec 2011
    Seaham
    Check tyres, wheel bearings for a start.
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Does it do it when turning or just in a straight line?
    durham
    Trim : Leather
    I've just put my set of winter wheels on so it's not tyres, straight line or corners noise is there all the time no worse on lock to lock which is when a driveshaft would knock. Wheel bearing?
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Did it start when you put the winter wheels on, or has it done it all the time?
    If so, then its likely to be the bearing.
    durham
    Trim : Leather
    It was there before I put the winters on dan.
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by tonyblade View Post
    Even though it didn't sound like it in my post, then its likely to be the bearing.
  1. rumbling noise
    By signum83 in forum Vectra C / Signum Car Chat
    Last Post: 31st August 2010, 21:00
  2. Rumbling
    By deathdisco in forum Engine & Drivetrain
    Last Post: 6th March 2010, 20:31
  3. CDTI 150 Clutch noise. DIagnosis required
    By 12345 in forum Engine & Drivetrain
    Last Post: 6th May 2009, 18:35
  4. Rumbling noise
    By Keyboard in forum Suspension, Wheels & Brakes
    Last Post: 5th November 2008, 20:29
  5. Road Noise / Rumbling rear wheels solved?
    By Raze in forum Suspension, Wheels & Brakes
    Last Post: 10th October 2008, 17:30
