Results 1 to 10 of 17
Thread: car and spanner light
    Oct 2012
    essex
    Default car and spanner light
    ok, i hoovered out the car car using the connector in the rear compartment and since then the spanner and car light has come up on the dashboard (could be a coincidence). as soon as i start the car it dissappears and the car runs brilliant.
    ive read using the search engine, "apparently" this is because a fault has been stored and it will go out on its own after a few restarts.
    but whats the point of that? other than to panic you the car might have a problem.
    do i need to be concerned at all?
    Yes, eventually the warning should switch off (either 10 or so start ups, or 48 hours)
    This is to allow easier diagnosis (known as stored codes) if the issue repeats
    If it only happens once or is erratic, don't bother about it
    The main concern is if the engine is placed into safe mode
    Again if it only happens once and is fine thereafter, don't bother about it
    I usually wait until it happens at least 50% of start ups or has become permanent
    Oct 2012
    essex
    well ive driven the car 4 to 5 times since the hoovering out and its still on at ignition and goes out when started.
    Oct 2012
    essex
    so if it dont go out on its own, even tho it goes on start up. should i get it checked? i assume if there was a "real" problem the light would stay on all the time?
    Is this the spanner in the Rev Counter (EMS warning light) or the spanner to the right beside the Fuel Tank warning light?
    If it is the spanner in the Rev Counter
    If you turn the ignition on, but do NOT start the engine, what happens?
    If you wait two minutes and then start the engine, what happens?
    I would not be concerned if the light stays on all the time
    This simply advises there is a fault and can be dealt with in due course
    I would be more concerned if the light stays on and the engine is placed into safe mode
    This has to be dealt with ASAP
    As an example :
    1
    a failing camshaft sensor can cause the EMS warning light to show briefly at start up
    This is not an essential sensor
    However when this sensor fails it will stay on all the time and put the engine into safe mode
    This is due to this type being known as a redundant sensor and relies on another sensor
    2
    A failing crankshaft sensor will put the engine straight into safe mode
    However on restarting the engine may start normally
    When this sensor fails it will always start in safe mode
    This is due to this type being known as a primary sensor and can be used by a failed redundant sensor
    Oct 2012
    essex
    cheers for the reply.
    its the car and spanner light in the rev counter. if i switch the ignition on it stays on till i start the car regardless of the amount of time.. as soon as i start the car.. it goes out and i dont see it again. until the next time the ignition is switched on.
    Are you sure it is regardless of the time?
    Sounds more like the time is coincidence
    The handbook however does advise if the warning light appears briefly to ignore it
    As an aside, I assume it is a manual transmission
    Oct 2012
    essex
    this what i got from the manual:
    Control indicator
    A for engine
    elect ronics
    (within tachometer display dial)
    If it lights when the engine is running, there
    is a fault in engine or transmission
    electronics. The electronic system switches
    to an emergency running programme. Fuel
    consumption may be increased and the
    driveability of the vehicle may be impaired.
    In some cases the fault can be eliminated
    by switching the engine off and back on
    again. If the control indicator lights up
    again when the engine is running, consult a
    workshop to have the cause of the fault
    remedied. We recommend a Vauxhall
    Authorised Repairer.
    If it lights b riefly, but does not recur, it is of
    no significance.
    Flashing with the ignition switched on
    indicates a fault in the immobiliser system.
    The engine cannot be started – see
    page 55
    Oct 2012
    essex
    ive just checked it again.. the light stays on the whole time if its just the ignition on. as soon as it starts, it goes out.
    Oct 2012
    essex
    yes its a manual box.
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. spanner light then engine management light
    By learoy69 in forum Engine & Drivetrain
    Last Post: 12th March 2010, 20:10
