Thread: Fitting a new EGR valve
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    Default Fitting a new EGR valve
    When fitting a new EGr valve to a 1.9cdti 150 which order do the bolts have to be tightened?
    Is it the 2x13mm and then the 4x10mm or the other way around,i just need to make sure that the valve is seated correctly
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    You'll find that you probably can't seat the 2 x 13mm ones with the 4 x 10mm ones tight, get them all in position first and I usually do the 13mm ones up before finishing the 10mm ones.
    Aug 2011
    Basingstoke
    Trim : SRI
    thanks mate
    Regular Member Mission1979's Avatar
    Castleford
    Engine : 1.9CDTi
    Mileage : 113000
    If like me you put a stainless steel part blanked oval in the lower section sandwiched between two normal gaskets to restrict the flow it becomes very difficult to bolt stuff together. I think I did the 13mm bolts first to enable you to push down on the egr allowing you to get 10mm bolts in.
  1. Fitting a dump valve like it or not !!
    By nath-lav in forum Diesel Engine related
    Last Post: 19th February 2012, 10:50
  2. fitting a dump valve
    By victorM in forum Engine & Drivetrain
    Last Post: 25th February 2011, 02:10
  3. Fitting an EGR valve to a 150cdti
    By robk6112 in forum Vectra C / Signum Car Chat
    Last Post: 25th May 2009, 13:41
  4. fitting a dump valve
    By jb-redbull in forum Petrol Engine related
    Last Post: 27th August 2008, 12:52
