Thread: clutch pedal tick
    slough
    confused clutch pedal tick
    hi guys and gals anybody had or got a problem where your clutch pedal does a tick when your pressing it down, its not the creak people talk about thats been done its a tick and its realy anoying it does the tick even with the extra yellow spring taken off ?
    slough
    cant belive no ones had this problem with all the vectra c `s out there....
    Regular Member Big Red's Avatar
    May 2011
    Dudley (Cramlington)
    I used to get a tick then got worse and was dmf mate
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by hippo View Post
    How many replies did you expect after 88 minutes late at night?
    Regular Member Tinks's Avatar
    Jan 2012
    Whittlesey
    Vehicle : Vectra C Elegance
    Engine : 1800
    Mileage : Lots
    Mine has started to do this aswell but it clicks on the way up as I am about to take foot off pedal. Only started about 10 days ago and its annoying - would like to know if the issues are related and what the cure maybe.
    slough
    mines beter not be dmf its only done 3,ooo miles since it was done, im on here most nights in the early hours and loads of players reply in even less time than that thanx for reply though...
    slough
    tinks yours sounds like the clutch switch i can take a look if you like thats not a big expensive job........
    slough
    im in slough too....
    Regular Member Mikey4996's Avatar
    Mar 2011
    Aberdeenshire
    Mine ticked and creaked. Changed the spring and problem solved.
    Ps. The old spring inner was creaking and the spring being stretched at one end and completely squashed at the other end was the ticking.
    HTH.
    Regular Member Lordish's Avatar
    Feb 2012
    Luton
    Mine also ticks on the way up
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. rattle on tick over and also when push clutch in
    By bridge_eee in forum Engine & Drivetrain
    Last Post: 10th April 2011, 23:01
  3. Clutch pedal
    By BigWilko in forum Engine & Drivetrain
    Last Post: 9th January 2011, 08:38
  4. clutch pedal
    By Tam80 in forum Engine & Drivetrain
    Last Post: 2nd September 2010, 19:41
  5. Clutch Pedal!!
    By andd306 in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2010, 21:48
