Results 1 to 10 of 13
Thread: Heater + Engine Temp
    Edinburgh
    Engine : 1.9 CDTI 150
    Default Heater + Engine Temp
    I have just completed a 360 mile journey and the whole way my engine temp didn't go above a max of 82 Deg and with the heater all the way on 4 and full heat, it was still freezing cold, can anyone help with this ??
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Possibly a dodgy thermostat and/or clogged heater matrix. Might be worth draining and flushing the cooling system
    Edit..... Or air mixer motor behind glove box faulty.
    ---Sent from my iPhone 4 using Forum Runner
    newport
    thermostat? very common failure on the vec c from what i have read
    Edinburgh
    Cheers will start looking into this on Saturday, will start with the mixer motor first, seems the easiest to do. Any chance it could be the Heater Controller Panel
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 139000
    some info for you
    and some threads i posted
    http://www.vectra-c.com/forum/showth...ighlight=coldo
    your temperature gauge should read 86
    82 is a little low
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 139000
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 139000
    the classic sign of a faulty temperature gauge is
    it sits at 0 for ages, moves up to 80 then drops back to 0 again
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 139000
    with the heater off what does your gauge read
    heater 4 will keep the gauge low
    Oct 2012
    coventry
    Quote Originally Posted by vectra ste View Post
    some info for you
    82 is a little low
    dam mines below 80c gose upto about 82 now and then but its nice and toastie inside
    Edinburgh
    Will check on friday when i next drive it and will let u know
  1. engine coolant/temp gauge/heater
    By redmoog in forum Engine & Drivetrain
    Last Post: 1st December 2010, 21:37
  2. engine coolant/temp gauge/heater
    By redmoog in forum Vectra C / Signum Troubleshooting
    Last Post: 1st December 2010, 21:27
  3. Temp Gauge An Heater Probs Any Ideas
    By alshel in forum Electrical & ICE (including SatNav)
    Last Post: 3rd November 2008, 23:30
