Thread: gearbox drive shaft seal
    Banned for Being a Numpty
    Jun 2012
    Default gearbox drive shaft seal
    need to replace drive shaft seal as gearbox is leaking and getting worse,anyone done this on f40 g/b??? or any how2s on ere? do i need special tools?
    Regular Member scotty84's Avatar
    Dec 2010
    Boosting in W.Mids
    Vehicle : Saab 9-3 Aero
    Trim : Aero
    Engine : 2.8 Turbo V6
    Mileage : 62000
    Oh dear dont sound good to me ....
    Hopefully someone will be along to answer your question. but thats a job I would leave to the pro's myself lol.
    Jun 2012
    surely cant be that hard?
    Regular Member Mr Owens's Avatar
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    Done mine a couple of months ago, easy job but the seal was £20ish with trade discount, on a ramp it took about 20 mins
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    36 Post(s)
    Engine : 1.9 DTH
    Seal is 11£ each and obviously driveshaft has to be disconnected
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Real easy job mate if you can get it in the air
    drive shaft out, then just prise the seal out I use a heel bar. Then tap new seal flush
    drive shaft back in job done
    Jun 2012
    sounds ok,i wownt say easy as thats when things go tits up for me lol,going to change gearbox oil too might aswell while im there....anyone got part numbers and oil...also how much oil as i remember somethink with being too much in them or sumit f40 g/b thanks again love this forum
    Jun 2012
    all done was easy as ....done lower arms n droplinks while i was there too,much tighter now for the rear,not looking forward to that...
  1. drive shaft oil seal replacement
    By skydivepaul in forum Vectra C / Signum Car Chat
    Last Post: 19th April 2011, 13:15
  2. Oil leak from o/s drive shaft seal
    By olid2002 in forum Engine & Drivetrain
    Last Post: 21st March 2011, 23:51
  3. Crank Shaft Oil Seal !!!! PLEASE HELP!
    By s0501291 in forum Engine & Drivetrain
    Last Post: 24th April 2009, 19:53
  4. Cam shaft oil seal leak
    By exclusive07 in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd January 2009, 22:05
  5. drive shaft
    By glynn in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2008, 12:44
insugnia leaking gearbox oil driveshaft
vectra c driveshaft seal
opel corsa lite drive shaft seal replacement
Opel corsa utility replacement of drive shaft gear box oil seal
drive shaft seal to gearbox renault scenic 08 plate
corsa vauxhall diesel change driveshaft seal
corsa lite driveshaft leaking oil
seal gear bpx drive
vauxhall combo driveshaft oil seal
vectra c leaking from driveshaft
seal in opel corsa drive shaft
opel corsa drive shaft oil seal
opel corsa gearbox seal removal
saab 93 aero leak in the gearbox differential seal
vauxhall zafira drive shaft seal replacement
change opel gearbox seal
vectra c turbo gearbox leak
renault scenic drive shaft problems
f40 gearbox oil leak
replace gearbox drive seal on vauxhall vectra
f40 gearbox oil driveshaft replacement
vectra c gearbox oil seal
vectra c f40 driveshaft seal
vauxhall insignia oil leak from drive shaft
