Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Thread: whining noise
    Regular Member Swedge's Avatar
    Jul 2012
    Scottish borders
    Default whining noise
    coming from the turbo, happens between 1700 and 2000 revs
    sounds like a police siren, it only seems to do it when the engine has warmed up though
    no smoke or anything
    its a vectra cdti 16v
    VIP-Member Z80's Avatar
    Apr 2008
    Noumea
    14 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    The bronze sleeve is dead. Did you notice you were consuming more oil lately ?
    As long as the axle has no play, you'll still be able to save it using a refurbishing kit. But don't way too long, or your turbines will end up striking the gousing and brake - and you'll be sorry if metal parts reach the cylinders.
    My variable geometry vanes were also completely stuck, so I changed the whole turbo (found a reasonable priced Garrett on eBay UK) and a kit. I'll clean up and repair the old one when I've got time, but it should be done, as the axle has no play at all, it's just hard to spin. I couldn't wait for the car to stay immobilized for too long. I'll have a spare turbo handy for the next time, that is approximately in 9 1/2 years in the new one lives as long as the first one...
    Oh, and I'm not losing any oil anymore.
    On the other hand, I also had a crankcase pulley that broke a bit later after having replaced the turbo, and it should have had problems correctly driving the accessories belt for years, making the engine becoming hotter than necessary, so I'm not really sure the turbo broke because the engine was getting too hot and the breather allowed too much hot oil to get out of the crankcase, lowering the overall pressure, or I was losing oil because the turbo sleeve was worn.
    In any case, after changing the turbo, you should also look for potential other problems related to cooling and lubrication, as otherwise it might shorten your new turbo's life. Anyway, if you killed your turbo, then your car isn't probably a yougster, so have all the engine checked for other possible failures to come.
    I went from having to add 10 litres oil a month to nothing, so the car really got a new youth after having changed just a pulley and a turbocharger...
    Jul 2012
    Scottish borders
    Thing is my car uses no oil at all, dosnt overheat or anything
    im guessing I can remove the boost pipe and check for play in the shaft?
    Apr 2008
    Noumea
    14 Post(s)
    Trim : Elegance
    Mileage : 75 000
    Yes you can. Also check for being able to spin it with your fingers.
    You'll check for axial play (front-back) and radial play (wobble it and check if it has any side play).
    Mine had none of them, but was very hard to spin. Hence the whining...
    Sep 2012
    expat Lancashire lad in the Midlands
    Engine : 3.2
    I had one of them every time I put my foot down. Turned out it was the missus.
    Jul 2012
    Scottish borders
    Quote Originally Posted by Z80 View Post
    so if it is stiff to turn is there anything i can do while its in situ to help it?
    Apr 2008
    Noumea
    14 Post(s)
    Trim : Elegance
    Mileage : 75 000
    Well, I advise you search the web for "VNT turbo repair". You'll find a lot of YouTube tutorial videos, for instance.
    The turbocharger is in two parts : exhaust side and intake side.
    Once you've unbolted the exhaust side snail, all the remaining parts are held together by a unique nut on the axle.
    You'll have to replace the sleeve that holds the axle and receives the pressurized oil film that allows the axle to spin, and to clean up the variable geometry vanes you'll discover after having removed the exhaust half.
    The refurbishing package contain washers, rubber seals, bronze sleeve, screws, nut, circlips... You should find one specific for your turbocharger family on the web. I think yours is a Garrett GT17 VNT (to be confirmed according to your engine type : Z19DT or Z19DTH).
    Quote Originally Posted by Yugguy View Post
    LMFAO
    Jul 2012
    Scottish borders
    Well, I advise you search the web for "VNT turbo repair". You'll find a lot of YouTube videos, for instance.
    wont it need re-balanced after that?
    i see you can buy fully assembled turbo cartdridges
    http://www.ebay.co.uk/itm/VAUXHALL-1...item3a7bad0898
    would these need re balanced?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Or you could start with something simple like checking for split boost pipes
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    Have you done the air box mod? mine is lound due to the extra air being drawn into the engine
  1. Whining noise from Altenator
    By Hammy in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2013, 20:47
  2. Whining noise - help needed
    By b17e30 in forum Vectra C / Signum Car Chat
    Last Post: 23rd June 2010, 08:22
  3. whining noise (HELP)!!!!
    By wilsons 1.8sxi in forum Engine & Drivetrain
    Last Post: 20th March 2009, 09:03
  4. Whining Noise
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 11th August 2008, 09:08
  5. Whining Noise
    By v6boy in forum Engine & Drivetrain
    Last Post: 13th May 2007, 01:13
2.2dti making a whining noise and smokes
car whines when accelerating vectra c
