Thread: Fitting a Nokia CK7-W Bluetooth Kit
    Nov 2012
    Default Fitting a Nokia CK7-W Bluetooth Kit
    Hi all,
    My 1st post as a newbie on the forum and as an owner.
    I have just recently converted from my 3.2 Omega Elite to my first 2.2 Vectra Elite on a 56 plate.
    Question: I have a Nokia CK7-W kit that was taken out of the Omega and would like to fit in the Vectra.
    Is it a straight forward job and are there any guides/tips etc on how to fit it please?
    I won't be needing the cradle as I have a HTC phone fitted elsewhere.
    Thank you in advance
    Regular Member 4ndy's Avatar
    Oct 2010
    Glasgow
    It is an easy job. The only downside is that I get a Nokia ringtone when my Android rings!
    Nov 2012
    Quote Originally Posted by 4ndy View Post
    I don't suppose you have or know of a guide to fit this do you mate?
    Oct 2010
    Glasgow
    The unit has a power lead with 4 wires.
    Connect the black wire to the vehicle ground.
    Connect the yellow wire to the MUTE connection of the car radio.
    Connect the blue wire to a switched live using the 1A fuse supplied. Not connecting this wire will leave the unit permanently live as long as a bluetooth phone is connected.
    Connect the red wire to a permanent live using the 2A fuse supplied.
    Hope this helps.
    slough
    its easyest i have ever fitted red to plus on battery black to earth the rest is plug and play fitted loads.....
    Nov 2012
    Hope this helps.
    Never fitted one before and not the brightest spark when it comes to car electrics, but hopefully with your advice above, I may be able to do it without setting fire to the car
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Red goes to any permanent live on the Vectra - I used the red in the Radio ISO connector
    Black goes to any ground point or link to a local Vauxhal brown wire... not to a Vauxhall Black wire!!
    Blue goes to an ignition live point, and so I connected mine to the cigarette lighter / charger socket black wire.
    Yellow is the telemute wire - the white sticker on your head-unit casing should tell you which one this is.
    Pin 11 on full CAN.
    Pin 30-something on half-CAN vehicles... 34 ish I think.
    Yours is a Full CAN vehicle, and so your telemute pin (Yellow wire) is Pin 11 in the big quadlock connector at the back of the radio.
    If you are not confident with wiring, I do not suspect that you will use the front car speakers to listen to the phone - Instead you will be using the standalone speaker ?
    Here is the Quadlock pin-out for fully fitting a CK-7W as I fitted it to the wife's Vectra-C.
    Nov 2012
    Thanks Robsey,
    If the weather holds today, I'll take a look and have a go
    I was given advice about the Parrot mki9200, telling me that it was much better than the CK7-W that I have. I do have an mp3 player which is currently hooked up the audio by an FM transmitter. Although pretty good, its a pain with all the wires.
    With the mki9200, can I use my mp3 player to control what I play or do I have to use the parrot kit supplied?
    Cheers again, Dave
    Regular Member Mr Owens's Avatar
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    The parrot kit does more than the Nokia like streaming music but the Nokia can't be matched for quality (calls) and ease of fitting
  1. nokia bluetooth car kit fitting without vda
    By Scotlad in forum Electrical & ICE (including SatNav)
    Last Post: 24th July 2012, 14:50
  2. nokia bluetooth car kit
    By stuart bigboy in forum Parts for sale
    Last Post: 25th February 2009, 21:56
  3. Nokia CK-7W Bluetooth car kit
    By Ian T in forum Electrical & ICE (including SatNav)
    Last Post: 8th August 2007, 21:14
  4. Nokia bluetooth car kit
    By jamesr in forum Parts for sale
    Last Post: 14th June 2007, 16:39
  5. Fitting Nokia bluetooth
    By paulieg in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2005, 12:59
vectra zc nokia bluetooth
