Thread: vectra 3.2 gsi abs light
    Nov 2012
    west wales
    Default vectra 3.2 gsi abs light
    New on here so hi to one ans all....have a vectra gsi 3,2 02 plate....just done the front cv boots inner and outer both sides put it all back together and the abs light is on as is the light next to it ( think its the stability one ) ? ....checked all fuses....all ok....checked all connections are clean and properly connected....took for a drive and altered speeds to see if the vlotage needed to reboot....lights still on ....only think I can think is I had to give the shafts a good old wallop to get them lose would this of caused a problem to the sensors??
    Thanks guys in advance.
    VIP-Member Das's Avatar
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    The sensor for the ABS is built into the hub, sounds a bit like you have maybe knocked it when doing your cv boot.
    Nov 2012
    west wales
    Thanks for that.....best replace hub then? I guess it wont reset or anything will it.
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    try take the battery off for 15 mins and see if that will reset it.
    Nov 2012
    west wales
    Hi...does any one know the torque settings for the three bolts that hold the caliper carrier to the hub bearing for the vectra gsi 3.2 also is there a torque setting for the hub 32mm hub nut....thanks.
  1. Vectra 1.8 (54) ECU Light
    By coolcatkelso in forum Engine & Drivetrain
    Last Post: 12th August 2012, 09:35
  2. oil pressure light vxr vectra
    By baz2003uk in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2012, 21:23
  3. all about the bad light on vectra...
    By kenp in forum Vectra C / Signum Car Chat
    Last Post: 9th January 2010, 00:33
  4. Vectra C N/s Fog Light
    By lillie in forum Parts for sale
    Last Post: 15th July 2007, 13:42
