Results 1 to 3 of 3
Thread: Changed starter motor now wont start
    Nov 2012
    nottingham
    Default Changed starter motor now wont start
    Hi all! new to the forum so if i make any mistakes please correct me.Right to the problem
    car packed up 2 days ago smoke coming from the starter motor area and wouldn't crank so i changed the starter (nightmare) and it now cranks but wont start, its always taken a while to start but it just refuses now, any ideas anyone ? got a awful injector seals feeling thanks in advance
    2004 vectra 1.9 cdti
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Did you make sure the wirings are plugged in and did u check no damage to it?
    Remove battery connectors and keep it disconnected for half hour while u do this, check wirings are not burnt, check battery strength, weak battery can fail to fully start car.
    Other than that. Codes need to be read.
    Nov 2012
    nottingham
    yeah checked everything i could see, its a new bosch battery it soon went flat though so ill put it on charge over night and see what happens, before i changed the starter the spanner light was on but since i changed it its gone should i get a spanner light if theres a fault? and also i left the battery off over night would this cause problems for the ecu/immobiliser? thanks
  1. Starter Motor How 2?
    By Danny.surname in forum Engine & Drivetrain
    Last Post: 22nd December 2016, 15:56
  2. starter motor
    By yorkshireborn in forum Vectra C / Signum Car Chat
    Last Post: 13th November 2012, 11:06
  3. Starter motor . help please
    By claudiu666 in forum Vectra C / Signum Car Chat
    Last Post: 8th November 2011, 17:15
  4. Starter Motor
    By Steeev in forum Engine & Drivetrain
    Last Post: 15th September 2008, 16:56
vectra c wont start not battery or starter motor
vauxhall changed starter now car wont start
