Results 1 to 10 of 21
Thread: Washer sensor pin location
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default Washer sensor pin location
    I have now got the plug for the sensor but need specify location on where the pin is plugged in. One other wire is ground wire. Help a fellow member please :-)
    Regular Member jimbo1987's Avatar
    Jan 2012
    southwest
    sorry mate cant help ya with that. but have you just done a tid to gid conversion? thinking of doing it myself but have had trouble finding a gid! was it fairly easy.
    Regular Member coldo's Avatar
    Scotland
    emmmm.... do you mean where the plug fits into the swasher bottle or where the wiring loom is for the sensor.
    The latter is taped up with the light loom. I managed to get mine down without taking the bumper off.
    As for the sensor into the bottle. You need to drill a hole if you dont have one already. Easy to do... I even did mine in place without emptying the water bottle... Got a bit wet mind you lol...
    Scotland
    @ Jimbo1987
    Hi mate.
    It's dead easy.... Take your time and follow the instructions on the guide and you will be fine.
    If you look on ebay for "Vectra C Display" loads come up. You done even need ones with the vent surrounds as the display will fit the TID scree mount. What you do need is the plug that goes in the back so message the sellers asking if they have this in advance.
    Make sure if you a half can bus car you get ethe right display etc for the car type. Try and find one for the same fuel type also... Petrol for petrol etc as these should work straight away without needing to be reprogramed. You will need th stalk also for a prefacelift car for them to work.
    I know it looks daunting but take your time and an hour max later you will have a fully working GID display!
    Jan 2012
    southwest
    Quote Originally Posted by coldo View Post
    @ Jimbo1987
    Hi mate.
    cool cheers! just dont want to pay out for 1 to find out its paired to another radio!! guna do it though it definately looks like a great mod, hate the standard tid. i did put blue lights behind the tid to make it a bit better but still looks crap...
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Quote Originally Posted by jimbo1987 View Post
    Cd40 opera with paired headunit from wife's dad's lock up so was a straight fit
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Hijacked my topic! Lol
    No i have a bottle with sensor already fitted, plug wiring from a member on here. Just need the pin fitted and plugged into the block under fusebox in engine bay. I need the info on which area or number i need to plug the pin into.
    I have a cut off block from a disused car and have no ider how to remove the pin from the block!! So need help on both things
    Scotland
    Ahhhh.. Sorry mate... No idea with that one... Are you sure the loom is not there already taped up to the passenger side light loom.... Two pin connector...
    Scotland
    If you car not a 2002? If so then the GID should not be paired as long as your fitting a prefaclift screen.....
    "Try to get a GID from a 02/03 car if possible as these are not paired to the radio,if you cant remember that it will have to be unpaired from what ever car you buy it from.
    To change TID -> GID in CDR-2005 CCR-2006 radios are only valid display codes EQ,XR,QX,WZ and EU"
    Its all here in this thread bud!
    http://www.vectra-c.com/forum/showth...-to-TID-to-GID
    PS sorry for the thread hijack!
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    1- how to remove a pin from this?
    2- location and which block for the sensor pin that goes in?
  1. sensor location
    By stret in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2013, 18:01
  2. Washer jet hose location + small how-to
    By Damo77 in forum Styling
    Last Post: 12th March 2012, 02:42
  3. Washer bottle level sensor location
    By EddyPole in forum Vectra C / Signum Troubleshooting
    Last Post: 21st September 2011, 20:15
  4. boost sensor location?
    By chowwie in forum Engine & Drivetrain
    Last Post: 30th September 2010, 08:00
  5. Tilt sensor location
    By steve in forum Vectra C / Signum Car Chat
    Last Post: 24th March 2010, 16:29
