Thread: how to clear a spanner light fault
    Sep 2012
    cheshire
    Default how to clear a spanner light fault
    i did a fault code check on my car and got 0246 turbo wastegate solenoid high. so i decided to remove my dump vale as the spanner/car light had been on since this was fitted, left my battery dissconnected for 5mins and then road tested. no light came back on and the car went a lot better. after i started a few hours later the light was on straight away and stays on. did code test and again 0246. have i still got the same problem or have i not got rid of it properly?
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Would need a fault code reader to delete, But leaving the battery off for 30 min, MAY delete the light.
    Disconnecting the battery is time consuming and inconvenient
    Normal practice to disable a fault code (so that safe mode is switched off) is to allow at least 30 minutes to pass and then restart the engine
    However for more serious fault codes safe mode remains enabled and the only way to resolve these is to replace the faulty part and to then repeat the process
    On restarting the EMS should then notice the change and disable the fault
    Regular Member megsdad's Avatar
    May 2011
    Northwich, Cheshire..
    8 Post(s)
    Vehicle : SRi Estate Nav
    Trim : Boring cloth
    Engine : CDTi 150
    Where abouts in Cheshire are you, If your local to me i have a fault code reader and im happy to delete the codes/spanner light for you.
    Sep 2012
    cheshire
    I live in winnington and work in winsford megsdad
    If you resolve the fault, then the car/spanner light should go out of its own accord once the engine is running.
    If it's on until the engine is running, its just indicating a stored but non current fault code. After 'x' amount of clean starts or 'x' days of clean starts, the stored fault code will auto delete.
    If the fault light is still on, then there must a problem that's still causing it.
    May 2011
    8 Post(s)
    Trim : Boring cloth
    Engine : CDTi 150
    Im in Lostock, if you private message me your name and number will call you to see about poppin' over...Regards Steve
  1. Help..Clear spanner light by disconnecting battery?
    By marky2027 in forum Vectra C / Signum Car Chat
    Last Post: 23rd April 2010, 13:01
  2. 2.2DTI Spanner fault Light.... HELP
    By n30jjb in forum Vectra C / Signum Troubleshooting
    Last Post: 15th June 2009, 08:42
  3. Spanner Light Intermittent Fault
    By jamesgsi1983 in forum Engine & Drivetrain
    Last Post: 16th February 2009, 22:08
  4. Spanner Light with P1191 fault code?
    By simp_2.2sri in forum Vectra C / Signum Troubleshooting
    Last Post: 16th October 2008, 20:14
  5. 2.0 dti spanner light fault!!!!!!
    By tommoturbo in forum Electrical & ICE (including SatNav)
    Last Post: 24th September 2006, 17:53
clear code spanner light
vectra dti does disconecting battery reset spanner loght
