Results 1 to 10 of 18
Thread: steering problem
    May 2011
    sunderland
    Default steering problem
    Hi guys ive got a 06 vectra cdti 1.9 120bhp and for a while now i have had bother with steering. It feels like tight spots when turning and then sometimes the steering wheel doesnt go back after turning also heavy steering but then it goes back to normal. There is also a creaking "plastic" noise coming through the steering wheel. Levels ok no warning lights .....any ideas thanks
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Drain and refill the power steering fluid.
    Or do what I did ..... Siphon out the fluid from the reservoir, then refill that with new fluid. Worked a treat for me, and saved a full drain / refill / bleed
    May 2011
    sunderland
    Ill give it a go did u have the same problems mate??
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by pud wayman View Post
    Identical problem mate
    May 2011
    sunderland
    Champion mate great advice and super quick reply ill let you know how i get on ta mate
    May 2011
    sunderland
    Hi mate ive drained off the old fluid looked like muddy water refilled it with new fluid ....no difference. Ive still got tight spots when turning also theres a plastic klunking noise coming from the steering wheel when turning. No warning lights on dashboard but sometimes the steering is fine .....possible battery problem or something on the suspension????
    Regular Member yessof's Avatar
    Jan 2008
    west yorkshire
    Happened to me a while ago. steering stiff at low revs. Battery replaced,problem gone. Power steering is electricaly operated. Best and cheapest option is test the battery. Good luck with it.
    May 2011
    sunderland
    When turning theres a clunking noise any idea what that could be mate
    May 2011
    sunderland
    Also when driving in a straight like the car pulls to the right
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Could be a CV joint if it clicks when you turn and accelerate.
    Otherwise a worn ball joint / track rod end / bush.
    Most likely to be tracking. But could be linked to the above
  1. power steering problem
    By Mikewigan in forum Vectra C / Signum Troubleshooting
    Last Post: 1st May 2012, 07:28
  2. Steering, yet another problem
    By alannorman10 in forum Suspension, Wheels & Brakes
    Last Post: 19th March 2011, 10:53
  3. Steering problem
    By dunkymunky in forum Suspension, Wheels & Brakes
    Last Post: 4th October 2010, 20:50
  4. Steering Problem
    By dudley6623 in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2010, 17:26
  5. steering problem
    By bigal12 in forum Vectra C / Signum Car Chat
    Last Post: 22nd December 2009, 23:37
