Results 1 to 10 of 14
Thread: CD 70 Bluetooth not working
    Dec 2010
    Newcastle
    Default CD 70 Bluetooth not working
    Hi Folks
    A couple of weeks ago the alternator on my 06 vectra gave up and as a result the battery went flat. After have the alternator replaced I noticed that the bluetooth on my cd70 has stopped working. The phone tab at the top of the screen is still there, but when I try to scan for devices nothing happens. When I make the car cd70 visable for three minutes my phone doesnt detect the car bluetooth either. Everything worked fine before the altenator glitch. You help would be very much appreciated.
    Many thanks
    Reynic
    Dec 2011
    Seaham
    Does it need switching on again via Tech 2?
    Dec 2010
    Newcastle
    Not sure Ben50n. I'm not up on the old Tech2 but is this something that has to be done to make the Bluetooth work after,say, disconnecting/ replacing the battery?
    Dec 2011
    Seaham
    I am not up on it either. I have the software that cannot be mentioned, if you can find which modules need switdhing on, we can check it?
    Have you tried linking up another phone?
    Dec 2010
    Newcastle
    Yes - I tried pairing my daughters phone with no success. Like mine her phone didn't detect the car bluetooth at all so it must not be turned on (with the 'visable for 3 minutes' button checked on the cd 70)
    Dec 2011
    Seaham
    In that case sounds like it needs to e switched back on again. There may be something on the forum on which module needs to be swiched on.
    You are welcome to come and try at mine? Unless someone else is closer.
    Admin plasma's Avatar
    On the Forum
    335 Post(s)
    Engine : 150
    Mileage : 74000
    These bluetooth units are prone to failure in the way that you describe. They will appear to work but when you hit 'search phones' or whatever it is to scan for them it wont find anything, Had 3 units do this...
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    Disconnecting the battery does not effect the bluetooth, well it doesn't on my cars. Unfortunately the software does not program the uhp4 module, you will need tech2 on it to sort it out or to programme in a replacement.
    Edit: plasma is on the case, he did mine so your in safe hands.
    Dec 2010
    Newcastle
    Thanks Guys - Safe hands are exactly what I need right now!!
    Dec 2010
    Newcastle
    Hi Folks
    Just a gentle bump!
    Many thanks
  1. radio working, not working, working again
    By J P S in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2012, 00:59
  2. Replies: 4
    Last Post: 11th November 2011, 12:05
  3. Replies: 0
    Last Post: 10th November 2011, 22:58
  4. bluetooth
    By mattv6diesel in forum Vectra C / Signum Car Chat
    Last Post: 27th November 2009, 15:55
  5. cd 70 bluetooth
    By m1w in forum Electrical & ICE (including SatNav)
    Last Post: 12th April 2007, 23:09
