Results 1 to 10 of 23
Thread: 4 new tyres.. 32psi... correct?
    Jun 2012
    Lincs
    Default 4 new tyres.. 32psi... correct?
    Hi guys, i know this has a few threads on what pressure to run in tyres etc
    I have just had 4 new tyres fitted and have changed from 215 50 17 to 225 45 17. i asked the tyre place to inflate them to 36psi as thats what i run normally, he said yes but i will be over inflating them..
    he said recommended tyre pressure for me was 32psi all round to which i mentioned my book says 33psi all round.. he then took me to the car to which the 2 fronts were on pads which showed how the tyre was sat on the floor... at 36 psi it showed that the tyre was running over inflated and that 32 psi was infact the exact pressure the tyre was sat at its best when i contact with the road...
    but still looking at them the look so 'flat'?? can this be correct?
    mpg still as high as it was when running 36psi
    opinions...
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    IIRC 32 is the correct pressure, but 36 is the ECO setting. Just had 2 tyres fitted this week, they put 32 in, I put it up then to 36 and tbh it feels really light now, so much so im going to lower it to 34 and see how that feels. I had my old tyres at 36 and they felt fine, maybe still need to scrub the tyres in.
    Quote Originally Posted by jamesb View Post
    The handbook states 33 or 35/42 for your engine, with that tyre size
    Why did you want to use 36?
    An odd response from the tyre fitter as they can use up to 46 in this tyre size
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    i now stick to paul the mods rule, x2 your wheel dia, plus 2 (psi)easy to remember.
    11 Post(s)
    I've always run my previous 215/50/17 and current 225/45/17's at 32psi all round.
    No abnormal tyre wear (apart from the usual wear on the inner edge of the rears)
    With radial tyres you're meant to have a slight bulge in the side wall at the bottom. If there is no bulge then they're over inflated.
    Jun 2012
    Lincs
    Quote Originally Posted by 06sri View Post
    which is why i use to run 36psi all round as i stuck to that rule, but then the tyre fitter showed me the contact point with the tyre and road and it was actually over inflated...
    i think i will scrub the tyres in then see how it feels then..
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    What about just strub the plus 2 so u always get 34 by using the revised rule of 2x dia equals. For over 17" tyres. Under 17 would have a plus 2. Makes sense to me.
    11 Post(s)
    Why not just set them to what the handbook advises?
    May 2012
    northumberland
    34 was a little soft i felt. 36 improoved the steering right up for me and with 36 you can afford to loose a couple of psi over time.
    Sep 2010
    nope,.. this means I'm running 38psi!!... am on 18s running at 34.
    handbook states 33 all round increasing to 36 depending on load. 34 covers it nicely
  1. Is this the correct Kit?
    By Vectra Dan SRi in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2013, 00:07
  2. These the correct ones?
    By golfpro in forum Vectra C / Signum Car Chat
    Last Post: 28th December 2012, 03:06
  3. Correct oil for a DTI
    By olid2002 in forum Engine & Drivetrain
    Last Post: 5th February 2011, 23:56
  4. correct oil
    By Dougb in forum Engine & Drivetrain
    Last Post: 27th April 2010, 14:27
  5. have VX used correct oil?
    By wardy in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2007, 20:58
