Results 1 to 10 of 15
Thread: Can you fit a 235 tyre to a 7.5" wide rim?
    Regular Member muffking's Avatar
    Default Can you fit a 235 tyre to a 7.5" wide rim?
    I have a set of 235/40/18's and a set of 18x7.5" rims. Will they fit ok.
    Should be ok fella but get one of the boffins on here to work out your rolling radius for you !!!!
    I normally use http://www.miata.net/garage/tirecalcold.html which worked the new tyres out to 79.8" as opposed to 80" on the old 17's
    Happy days then dont think the width is a problem as i think Nutron runs 235's on his standard 17's !!!!
    Brilliant. I wasn't sure if it had to be an 8" rim, but I'm happy now
    Regular Member James C's Avatar
    Essex
    Engine : 2.8 Turbo
    A 235 should be ok on a 7.5" rim and it will clear the arches no problem, I've got 235's on my Vauxhall 19's.
    Regular Member andrewp3883's Avatar
    Derby
    Should be no problem. I have 235's on my 8 inch rims and was asked if i wanted 245 or 255's when they were fitted but was unsure of the arch clearance but needn't have worried. There's loads of room and loads of scope left as my tyres almost have a bit of stretch on them if you know what i mean.
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    I do indeed have 235s on what I now know to be 7J so you should have no problem with them.
    P went sideways up a curb and the tyres didn't shift an inch. You might need to increase the psi slightly to achive uniform wear though.
    Go for Toyo T1-Rs, they are great in wet and dry.
    Cheers guys. The car manual says that the old 17"s should be around 40psi, roughly what should the 235/40/18's be?
    Leicester
    You want to base the tyre pressures on VXR 18" rims, these also are 235 40 18" tyres. You would have no problems in over all tyre diameter, but regardless to what people have said you are actually on the limit with a 7.5" rim.
    This is why Vauxhall decided to fit 225 45 18" tyres on the 7.5" rim and 235's on the 8" rim. If you look at all the manufacturers out there, they all use an 8" rim for 235 upwards.
    I always base my theories on what the manufactuer works with as they spend hundredsof thousands of pounds on research and development.
    My concern would be the heavy weight of the 3.2 with this wheel and tyre set up.
  1. Correct O.E tyre sizes for 18" & 19" wheels
    By ROCKATANSKY in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2010, 09:26
  2. FOR SALE: Toshiba 28" Wide Screen Flat CRT TV silver VGC
    By merikiito in forum General items for sale
    Last Post: 3rd November 2008, 16:02
