Results 1 to 10 of 26
Thread: cdti boost gauge
    Banned for Being a Numpty
    Jun 2012
    Default cdti boost gauge
    looking to fit a boost gauge on my 1.9cdti 150 sri....1st off what gauge...wt type? i know you have to pipe into the hose between the battery n engine,correct me if im wrong....does it matter where in particular? then just a case of mounting gauge routing pipe connect wires n thats it or have i missed something? sounds easy lol
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    Don't even need wires if you don't mind it not lighting up. Need to put a connector in the hose just before it connects to the engine - the one that runs past the battery cover and turns right to the throttle body by the EGR. Run some silicone hose from there to the access hole behind the fusebox etc which will go to the passenger footwell behind the glovebox. Run it behind the dash and to wherever you want then. If you need 12 volts for a light, there will be wires nearby but probably just as easy to run it from the cigarette lighter wires because they're switched with the ignition.
    Jun 2012
    does it matter what gauge vac or mechanical not clued up on them really,just a nice to have if problems occur
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    Mechanical has less to go wrong and tends to be more accurate, thats it. Just pick what you prefer.
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Fitted one to my DTI, it's a mechanical and works fine. I fitted a 2 bar gauge to see how much overboost was flagging a fault, quite a nice addition to the dashboard
    Regular Member tazdog03's Avatar
    May 2011
    barnoldswick
    any photos of one fitted pls
    Jun 2012
    im putting mine in the vent,as the flaps are broke on the heater anyway,and ive used the broken vent to fix the rest lol...just gota get a gauge n fit it,ill do a how to i rekon...
    Nov 2011
    This is the one i got, and comes with the fittings you need to get it working on a diesel (cos there's nowhere to tap a t-piece into) http://www.ebay.co.uk/itm/Smoked-BLU...item3f1d9f4774
    This is turned off
    And turned on (bit blurry, cold outside and hands were shaking lol)
    Jun 2012
    looks smart...did u tap in to the big pipe? any where specific?
    Nov 2011
    I tapped into the manifold top section (where the hose connects to). Took it off the car, drilled a hole through it, tapped a thread on it, and screwed in the supplied brass nipple with thread tape on to make it airtight. Ran the piping through the drivers side firewall gromet to the gauge and job done.
    I intended to fit it as a temporary measure to find out how much boost was being produced when it went into limp mode, which is why i havn't put it in a pod. I quite like it so i might mount it to the pillar instead of using the supplied holder.
  1. 1.9 cdti boost gauge how 2
    By DAVIDD88 in forum Engine & Drivetrain
    Last Post: 19th January 2013, 18:33
  2. Cdti boost gauge
    By winnie2457 in forum Diesel Engine related
    Last Post: 21st February 2012, 02:48
  3. Boost gauge cdti 150 fitting.
    By Avin in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2012, 16:20
  4. boost gauge 1.9 CDTi
    By CristianTM in forum Diesel Engine related
    Last Post: 10th October 2009, 22:56
  5. cdti boost gauge
    By davidjameswest in forum Vectra C / Signum Car Chat
    Last Post: 20th July 2009, 00:17
how to fit vectra cdti boost gauge www.vectra-c.com
