Thread: Gear box/change
    Regular Member Jim Bob's Avatar
    Widnes, Cheshire
    Default Gear box/change
    Hi all,
    I've been driving an Astra today and remembered how good the gearbox was in my old one compared to the Vectra. Does anybody else feel it lets the car down slightly? I know its meant to munch miles on the motorway, but sometime regular changes are unavoidable.
    Why does it feel so different?
    I drive an 2006 SRi, so is this what vauxhall would call a sports gearbox - or are they the same in all models?
    [Ex]Admin Duncan's Avatar
    The five and six speeds are the Wide Ratio, expect the one in the 2.0T which is a close ratio, I suppose what you could term a 'sports' gearbox.
    If yours is the six speed (F40) box then they were known to suffer from notchy changing - some peoples boxes took this to the extreme and crunched into a few gears and were replaced under warranty.
    Vehicle : i500
    Trim : i500
    Engine : V6 3.0CDTi
    I have had a new box (F40) on my 3.0 cdti after 4800 miles and 10 month old
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    I must admit that the box on mine lets the drive down. Mine suffers mainly going in to second but it's quite notchy all the way through.
    Regular Member Big Davie's Avatar
    Jan 2006
    having a giggle...
    I got a new gear box in mine just before crimbo, the fault came under the "cold start" problem, ie 1st and 2nd were a bit stiff when the car was cold.
    When I asked VX about this problem they said they have a fitting kit for other gear boxes but mine and the F40 were different.
  1. cdti stiff gear change, removing gear turret?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2017, 03:14
  2. 1.8 vvt gear change
    By davidpickard in forum Engine & Drivetrain
    Last Post: 12th December 2011, 12:16
  3. gear change
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 6th March 2010, 09:31
  4. Stiff gear change, gear selection fine though
    By tramman in forum Engine & Drivetrain
    Last Post: 24th November 2009, 23:20
  5. change gear
    By aptoman in forum Engine & Drivetrain
    Last Post: 3rd June 2008, 23:16
