Thread: front brake pads moving
    Regular Member andy_richmond's Avatar
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    Default front brake pads moving
    whilst looking for a clunk from the front of the car, seperate thread. i thought i would grease up the caliper slide bolts, forgot to do when i changed the pads. i noticed the discs still hadnt worn very well, there is a 3 or 4 cm of surface not touched by the pads on the outer edge of the disc, i thought it was just the old pads that were shot, but the new ones arent touching either, on the outer side of disc, all shiney on the whole surface. also the rear pads, the ones connected to the piston move, only 3mm but they def move, is this normal??? they dont move outwards, just rock in the carrier
    Regular Member rozzer2006's Avatar
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Engine : 2.8 v6 Turbo
    Mileage : 69k
    i had this same problem, are they GM pads??
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    no, eurocarparts ones
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Mileage : 69k
    thats probably ure problem, i replaced mines with GM ones, sorted. extra 10 or 15 quid but worth not having the hassle. i take it u have the 285 calipers? do u know??
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    I had exactly the same problem with my front brakes because i didnt put the pad spring back in properly,the pads wernt touching all the disc and they were clunking due to them moving
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Mileage : 69k
    i think the calipers dont like the cheapos they look exaclty the same as the GM ones i think it might be somthing to do with the anti squeek pad on the back of them. i would replace them with the GM ones see if that solves ure problem.
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Are they clunking as your pressing the brake cos mine is doing this but only when i touch the brake softly and its doing my head in.
    Admin plasma's Avatar
    On the Forum
    180 Post(s)
    Engine : 150
    Mileage : 74000
    also there are 2 types of rear brakes with a year breakpoint on them, there is a 1mm dfifference between the pads which enough for them to rattle, been there done that and then got the correct type
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    the only clunk i am getting is after i brake and pull away, but thats a seperate issue i think, maybe droplinks or arb bushes. how loud can the clunk be from the front pads, would i be able to feel it through the floor
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    I feel my through the brake peddle.
  1. Replies: 15
    Last Post: 8th January 2013, 10:11
  2. Vec B front brake pads 1.8, will they fit the Vec C?
    By Caveman_nige in forum Suspension, Wheels & Brakes
    Last Post: 23rd September 2011, 22:14
  3. front brake pads
    By rick1965 in forum Vectra C / Signum Car Chat
    Last Post: 16th September 2009, 12:37
  4. front brake pads
    By stevietiger in forum Vectra C / Signum Car Chat
    Last Post: 4th April 2006, 22:00
vectra c rear pads moving
