Thread: Brake Help
    Regular Member Badger59's Avatar
    Sep 2010
    Telford
    Default Brake Help
    Hi just changed the front pads (Vec C 2004) as the warning light had come on lastnight.
    Refitted the sensor wire but the light wont go off!!
    Any suggestions??
    Once the warning light has come on, you need to replace the sensor.
    Either that, or short the wires together going to it. Personally though I would prefer to change the sensor for less than £10.
    Dec 2011
    Woking
    Trim : Exclusive
    Engine : 1.8vvt (Z18XER)
    Mileage : 58000
    I've just read about this on another forum. This is a devious system - there is actually a wire loop at the tip of the sensor, covered by plastic. Once worn through, the wire loop is cut to open the circuit which trips the warning light.
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    13 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Its a failsafe system...ur choice to either replace the sensor or join them together to complete a non functioning safety circuit
    Quote Originally Posted by Dal5band View Post
    This is a devious system.
    What's so devious about it?
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    Just link it out mate....Fail safe....Safety circuit...! its just an indicator to tell you your pads are getting low. Its just as easy to take a look every now and then like in the good old days. Spend the £20 you save by using your eyes on a treat for ya kids.
    as soon as you link it out the light will go out.
  2. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  3. brake help please
    By sristeven1 in forum Suspension, Wheels & Brakes
    Last Post: 20th September 2010, 18:30
  4. yellow brake calliper brake set
    By The Gas Man in forum Parts for sale
    Last Post: 22nd July 2010, 22:41
  5. What brake pads for 2.8 V6 Signum??? 314mm brake discs
    By luke4487 in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2010, 23:21
