Thread: I've found this with cars paperwork. What does it mean?
    Regular Member Mission1979's Avatar
    Castleford
    Engine : 1.9CDTi
    Mileage : 113000
    confused I've found this with cars paperwork. What does it mean?
    So I have a receipt from a main dealing from a number of years ago before I got the car.
    It had 40k on the clock and had a;
    Reprogram ECU & Regenerate DPF
    and in the code section T112000
    I discovered car had a DPF recently with info from this site and it is a diesel estate.
    Wish it did not have one, want to go mad with tuning box.
    Plus I also found the Key Code, which I got given from the locksmith only two days ago that cut me a new key as I did not have the car pass. Typical.
    Glasgow
    It means the previous owner has'nt done journeys which allow the DPF to regenerate or has been turning the car off mid regeneration causing the DPF to block. It then requires a forced regen which is what the dealer has done.
    scottish region
    Dealer done forced regeneration as someone's had problems with dpf
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Its had an ECU update too.
    Castleford
    Engine : 1.9CDTi
    Mileage : 113000
    Wish the previous owner had just had it removed. Why oh why did they have to fit DPF to estates?!?
    Quote Originally Posted by Mission1979 View Post
    Due to the changes in emission requirements, as a result of a number of factors the majority of estates fell just below the requirements so had to have a DPF fitted (drag resistance, exhaust emissions and fuel efficiency)
    Four years later the next set of emission requirements meant that all body types (of this vehicle type) fell into this category
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Remove the DPF (clean out the innards).
    Get a remap done with DPF off and get some extra power done with the re-map.
    Fitting tuning boxes is a sure way to mess the whole fuel/turbo/exhaust systems.
    Nov 2012
    West Lothian
    Or just run a long masonry drill up the dpf from the rear. You don't have to remove it from the car to do it.
    Just remove the temperature sensor from the side of the DPF unit and don't go so far into the dpf that you hit the catalyst at the front. A 450mm drill is just long enough.
    Here's what mine was like after drilling http://www.flickr.com/photos/2849605...in/photostream
    MPG jumped up and performance is pretty lively now.
    Even just drilling halfway into the dpf made a pretty big difference, mine was badly blocked when I started experimenting and found that running 3 or 4 holes with a 12mm masonry drill halfway up the length of the dpf assembly was a good fix
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Not if the tail pipe points down. Don't argue m8internet, my 61plate Megane didn't have a DPF.
  1. Replies: 4
    Last Post: 4th April 2011, 06:34
  2. found this
    By andy76 in forum Vectra C / Signum Car Chat
    Last Post: 12th January 2009, 14:22
  3. Legal Plates without the paperwork
    By deanos in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2008, 18:46
  4. I hate paperwork.
    By shan in forum General Chat
    Last Post: 11th January 2008, 16:12
  5. found my cars double
    By big phil in forum Vectra C / Signum Car Chat
    Last Post: 20th September 2005, 18:45
