Thread: EGR help!!!
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    Default EGR help!!!
    Just fitted a new EGR valve to my 1.9 150 but when i rev the engine theres a hissing and then a popping sound.Also the car sounds like its struggling to breathe and then surging.
    I did squirt some carb cleaner down the EGR hole so could it of just dislodged some gunk?
    Any ideas what it could be?
    Jul 2011
    UK
    Year : 06
    U might not of tightened all the bolts up properly and got gasses escaping
    Aug 2011
    Basingstoke
    Trim : SRI
    they are all tight but i might just loosen them off and re-tighten them again.It does sound like the gasses are escaping though
    Aug 2012
    you did retrieve and put the gaskets back on too? every connection has one.
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Quote Originally Posted by justin32 View Post
    Be careful - don't over tighten them - if it is anything like the 120 the threads are easily stripped in the EGR housing.
    Aug 2011
    Basingstoke
    Trim : SRI
    old unit back on and its fine now...must be a cheap patent part
