Thread: Clutch Life Expectancy
    Barrow In Furness, Cumbria
    Default Clutch Life Expectancy
    I know it depends more or less 100% on how its been driven, but I overtook a car earlier and from 4th to 5th at around 5000rpm it took a second or so for the revs to drop. Should it not be pretty much instantaneous as soon as the clutch is out?
    Car is a 2008, 1.8VVT. Only got 40,000 miles and I got it when it was on 26,000.
    I think I know the answer that the clutch is starting to go, but wondered if there was anything that limits the power to the gearbox at high revs when changing gear?
    I can honestly say that the clutches on my cars have the easiest life ever as, (without being big headed) I have very good clutch / accelerator control and never need to set off at revs higher than around 1300rpm, even on hill starts etc.
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    could be due to the fact the car was hanging onto the revs during a gear change & literally forced the clutch to slip , if this is the only time it has done it then i wouldn't worry .
    Nov 2010
    East Midlands
    Trim : design
    I would think a modern clutch should last the life of the car if driven with consideration and you are not unfortunate enough to have a mechanical component breakdown causing it to fail
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    The old fashioned to test the clutch used to be to start the car, stick it in 4th and lift the clutch. If the car stalls right away the clutch is fine, if it slips, you will know about it and the car will keep running. More likely to have been the rubbish fly by wire throttle than the clutch imo.
    Jun 2011
    wolverhampton
    You could have an oil leak causing the slip?
    Cheers, I''ll just see how it goes.
  1. Life of a clutch and dmf
    By don1966 in forum Engine & Drivetrain
    Last Post: 6th February 2013, 22:00
  2. Car Life Expectancy
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 9th May 2012, 15:21
  3. Life expectancy.............
    By scoobs in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2009, 17:01
  4. VX shock absorber life expectancy :(
    By simac in forum Suspension, Wheels & Brakes
    Last Post: 17th October 2007, 07:50
  5. Clutch life ....
    By DennisTheMenace in forum Vectra C / Signum Car Chat
    Last Post: 10th July 2007, 15:09
life expectancy vectra cdti clutch
vectra c clutch life
vectra vvt clutch interval
