Thread: P2279 fault when egr mapped out.
    Jan 2010
    Perkinsville, County Durham
    Trim : Sri nav
    Engine : Z19dth
    Default P2279 fault when egr mapped out.
    What else could be the problem if I occasionally get p2279 when the egr valve has been mapped out and blanked off?
    scottish region
    Maybe not removed properly
    Jan 2012
    Gloucestershire
    P2279 is an intake leak error - so although I don't know for sure how the ECU makes a decision on this, it sounds like the MAP sensor is not agreeing with the MAF sensor - i.e. the pressure in the inlet manifold isn't what it should be given the air flow measured at the MAF. So the following springs to mind:-
    1) air leak between MAF and MAP - so hose from MAF to turbo, turbo to intercooler, intercooler itself (probable), intercooler to inlet manifold.
    2) dodgy MAF
    3) dodgy MAP
    Engine : 1.9 CDTi
    I had this and was sure it was my EGR.
    Turned out to be a leak where the flexi pipe after the AFM meets the 90 degree pipe.
    The jubilee clip was tight and everything looked fine till I used a smoke machine on it and it was leaking quite a bit. Bit of silicon on the pipe and refitted it and its now fine.
    Sep 2011
    Caerphilly
    Vehicle : saab 93 tid(150)
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    Easy way of testing for intake leak(between maf and turbo) is remove maf with pipe still attatched start the car get someone to rev gently and put your hand over the front of maf it will suck a bit but if theres a leak you will know, leaving the maf still attatched stops the eml coming on
  1. HELP! cleaned EGR now have fault p2279
    By frasedeb in forum Engine & Drivetrain
    Last Post: 17th February 2013, 14:07
  2. Fault code P2279?
    By Phil MC in forum Engine & Drivetrain
    Last Post: 8th July 2012, 19:29
  3. 1.9 CDTI fault code P2279-11
    By mozzer99 in forum Engine & Drivetrain
    Last Post: 14th June 2011, 20:13
  4. fault code p2279
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 20th November 2010, 20:14
  5. Fault code P2279 Showing.HELP!!!.Info PLEASE.
    By felixx in forum Engine & Drivetrain
    Last Post: 28th October 2010, 18:34
p2279 fault code www.vectra-c.com
saab p2279-02
vectra c 1.9 cdti p2279 error
p2279 saab 93 diesel
p2279 saab tid
